Can I get some thoughts and opinions regarding Echo chainsaw?
   / Can I get some thoughts and opinions regarding Echo chainsaw? #81
Had to buy a new echo this past weekend. Another cs400. My wife's old cs400 bar oil pump went out. For $320 and all we have had to do to it lately, cheaper to buy new and I got a parts saw.
10 years with the old one and she used it all the time, about 3-4 times a week. I feel I got my monies worth out of it.
   / Can I get some thoughts and opinions regarding Echo chainsaw? #82
I've had a CS400 for nearly ten years now. It's been trouble free, starts easy and has plenty of power for a 40cc chainsaw. My nest saw is going to be either the Echo CS-590 Timberwolf or the or the CS-620. As I man in my later 60s the CS-800P is getting too big and heavy.
   / Can I get some thoughts and opinions regarding Echo chainsaw? #83
I won't be felling any trees more than 8 inches or so in diameter; I will mostly be de-limbing, and cutting up brush.
Anything larger I'll bring in someone with more knowledge.
I have two Echo CS-490. I use the can fuel since I don't utilize the saws that much and the fuel seems to keep well.
I did buy an electric saw that I used for de-limbing and 4" or smaller trees. If I was using it a lot I would have a spare battery.
The gas saws are good when cutting larger trees or cutting quite a few trees at a time.
   / Can I get some thoughts and opinions regarding Echo chainsaw? #84
Prefer Stihl but have no quarrel with Echo. Definitely NO ETHANOL.
I do have two Echo's but if I did all over again I would have bought the Stihl.
I had a guy that cuts trees for a living and he likes the Stihl and the price doesn't seem to be that much more.
If I was using my chainsaw weekly I would use non-ethanol gas but since I use my so infrequently I utilize the can gas.
   / Can I get some thoughts and opinions regarding Echo chainsaw? #85
When shopping for my 620p the Husky was about 50% more and the Stihl was about double for the same class. So the Echo was a no brainer and it has run great can done a lot of work for me and it well balanced in the cut. A bit heavy to do walk about so I usually cart or tractor it to where I need it.
   / Can I get some thoughts and opinions regarding Echo chainsaw? #86
I am amazed that Echo still makes their equipment in Japan. I'm still evaluating the difference between my Husqvarna and my Echo chainsaws. They feel a bit different from each other, but that's about all I would say at the moment.
When it comes to pole saws, however, there's a radical difference in quality and performance between the Echo PPF-225 gas pole saw and the inexpensive gas pole saw attachments I have been using.
   / Can I get some thoughts and opinions regarding Echo chainsaw? #87
I'm an echo fan my dad still has the old echo saw I learned on, its heavy and has a 16" bar null of most modern safety features but it's 40 yrs old and still has ok compression. If I get around to it I'll rebuild the carb and use it again. I own a cs 400 18" bar has ok power to weight ratio always starts, however if you wear gloves when cutting you will probably unintentionally engage the chain brake (or I have a few times). Imo echo is a great brand at a fair price for decent quality for the overly motivated diy homeowner/ hobby "farmer".
   / Can I get some thoughts and opinions regarding Echo chainsaw? #88
That 800 will beat you up. I don't use our 36" 800 too often but when I need too it's good to have. I feel it the next day though and I'm only 50
   / Can I get some thoughts and opinions regarding Echo chainsaw? #89
I'm impressed with how the 590 pulls (though to be honest I've never used another big/bigger saw) but I will say, that thing is heavy enough, I definitely just pull it out for the bigger trees on my land.
   / Can I get some thoughts and opinions regarding Echo chainsaw? #90
I know an engineer that worked for Husqvarna and he said he would only buy the products actually made in Sweden.
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A58017)
1999 INTERNATIONAL...
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
