sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,774
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I need to replace 220 slit seeder bolts that are in an awkward position with tight range of wrench motion. plus I need to get them on pretty tight. After doing a few, I learned a longer 11/16" wrench would save hours of effort plus do a better job. There are longer wrenches sold but I still need a little more. So, can I get two cheapies, cut in half and weld the two longer pieces together? The question is; will the weld hold or will the heat weaken the wrench or what else will go wrong?
It seems the "black oxide" type wrench will weld better because there is no chrome to grind off but I'm not sure what black oxide is. Basically I need a double ended wrench 2" longer than the 14 5/8" longest one I can find. My plan is to cut in half, grind a "V" at the edges to be joined and turn the power up on wire feed. any comments or advice welcome. I'm an advanced beginner with a Lincoln MP210.
