Can hydraulic shuttle be added to a geared tractor?
   / Can hydraulic shuttle be added to a geared tractor? #31
One possibility would be to add a hand lever to the clutch pedal.
I have heard of this being done, I haven't seen once other then on some of the older tractors.
I saw one on a car over 50 years ago. As I remember it was basically a lever hinged to the steering column and attached by a connecting rod to depress the clutch pedal. There was probably a mechanism to adjust the length of the connecting rod and a hinged connection or two between the clutch pedal an the hand lever.
Because the driver would have had trouble holding the steering wheel and working both the clutch and gear shift, I doubt it would be legal today and don't know that it was legal back then.
The driver was a fill in preacher at our church.
   / Can hydraulic shuttle be added to a geared tractor? #32
Maybe a cylinder to operate the clutch and a 3rd function remote type actuator located somewhere convenient to the operator - maybe on the shift lever?
   / Can hydraulic shuttle be added to a geared tractor? #33
I worry about edging up to a drop off, worrying some cotter pin is going to fall out of a linkage and over I go. With all the focus on safety these days, can this even be a serious question? Save your knees and loose your life.
   / Can hydraulic shuttle be added to a geared tractor? #34
That possibility exists with used and repaired factory linkage.
   / Can hydraulic shuttle be added to a geared tractor? #35
Or even a brand new unit. If it is mechanical or electrical, it can fail.
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
CANOE (A56859)
CANOE (A56859)
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
New Holland WorkMaster 37 (A53317)
New Holland...
golf cart (A55787)
golf cart (A55787)
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
