Can hydraulic shuttle be added to a geared tractor?
   / Can hydraulic shuttle be added to a geared tractor? #31
One possibility would be to add a hand lever to the clutch pedal.
I have heard of this being done, I haven't seen once other then on some of the older tractors.
I saw one on a car over 50 years ago. As I remember it was basically a lever hinged to the steering column and attached by a connecting rod to depress the clutch pedal. There was probably a mechanism to adjust the length of the connecting rod and a hinged connection or two between the clutch pedal an the hand lever.
Because the driver would have had trouble holding the steering wheel and working both the clutch and gear shift, I doubt it would be legal today and don't know that it was legal back then.
The driver was a fill in preacher at our church.
   / Can hydraulic shuttle be added to a geared tractor? #32
Maybe a cylinder to operate the clutch and a 3rd function remote type actuator located somewhere convenient to the operator - maybe on the shift lever?
   / Can hydraulic shuttle be added to a geared tractor? #33
I worry about edging up to a drop off, worrying some cotter pin is going to fall out of a linkage and over I go. With all the focus on safety these days, can this even be a serious question? Save your knees and loose your life.
   / Can hydraulic shuttle be added to a geared tractor? #34
That possibility exists with used and repaired factory linkage.
   / Can hydraulic shuttle be added to a geared tractor? #35
Or even a brand new unit. If it is mechanical or electrical, it can fail.
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2007 FORD F-550 XL SUPER DUTY CHASSIS TRUCK (A58375)
2007 FORD F-550 XL...
2007 International 4200 S/A Chipper Truck (A56858)
2007 International...
