Can anybody identify this plow or manufacturer?
   / Can anybody identify this plow or manufacturer? #11
I think a standard edge has holes 12" on center. Also, instead of skid shoes, I sandwiched a piece of rubber between the plow and the cutting edge, so it hangs down a few inches. As soon as you drive forward, that flap will fold down and prevent the plow from digging into gravel or grass. It works excellent, although not as well on pavement as a normal edge. It is a nice option, as I have terrible luck using skid shoes. I have also heard of people slicing PVC pipe and sliding that over the edge, which should do the same thing.
I tried that with my back blade last year... Pipe lasted about 5-10 minutes. I'm planning on starting with just the skid shoes & going from there depending on how well it works.
   / Can anybody identify this plow or manufacturer? #13
Why not do both, the rubber flap "and' the shoes.
I got the skid shoes late in the season, so need to see how they work. My biggest problem is the 6-7' light duty truck plow I just picked up. Almost finished designing the SSQA frame for it. It needs shoes as well. Depending on how well it works, the back blade might be getting sold as I already have a box blade as well.
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2013 KENWORTH (INOPERABLE)W9 SERIES (A50854)
2013 KENWORTH...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
2010 FORD F-650 (A50854)
2010 FORD F-650...
