Can all tractors flip over easy?
   / Can all tractors flip over easy? #21
I didn’t think “flip” and “roll” were directional terms. Why can’t something be flipped on its side, or rolled over backwards?
OP, if you’re inexperienced, get a tractor with a roll bar (ROPS) and WEAR THE SEATBELT. A ROPS without using the seatbelt is just as dangerous as having no ROPS.
As far as flipping / rolling the tractor over backwards, always be aware of where you’re pulling from. Anything connected to the rear of tractor (or 3 point hitch) above the height of the rear axle will want to “flip” the front end up when you pull.
   / Can all tractors flip over easy? #22
I thought about buying an older tractor like an 8N, but then I started reading about them flipping over. I'm sure you can use common sense be pretty safe, but I got to thinking that maybe all tractors could flip? Was looking for advice on safety. I was thinking I probably need a sub compact now because they look safer, but I could be fooling myself.
It for plowing new ground with stumps and roots, mostly the leftover roots.
Edit: I have no experience with tractors, if you couldn't tell.
No, they don't flip over very easy. It's more that people who use them tend to put them in positions where they get unbalanced.
A lot of times it has to do with trying to do things beyond common limits. Flipping is so rare there aren't many rules. Common sense covers most of things as problems have as much to do with the person as the tractor... more so, if anything.
Pull down low and it won't flip. If you use the tractor on extreme slopes or pull on things at odd angles or from high on the tractor then you bet you can turn one over. Otherwise you'll never come close to turning one over.
If you tend to fall over on your motorcycle, off ladders, roll cars, and never could get the hang of skiing or skating - or are a "hold my beer and watch this" kind of person..... then better avoid tractors too.
rScotty
   / Can all tractors flip over easy? #23
Well, I have a vivid memory of climbing a hill in a 1952 Allis Chalmers tractor (wide-track, not the narrow gait of the pre-War models). I must have stopped midway for some reason, and when I started up again I apparently engaged the clutch too quickly. The front wheels rose off the ground for what seemed like a foot. My heart nearly stopped. But all was well.
My more recent tractors, a Japan-built Allis and an India-built Mahindra, have no such problem, or perhaps I'm a bit smarter than I was 45 years ago. (And Mahindra Baba of course has no clutch as such. I suspect HST is a great safety feature.)
   / Can all tractors flip over easy? #24
If you lack experience on the tractor, first get used to the controls, how it works, what you need to do, where your feet rest, how to kill the throttle, repeat it to learn muscle memory. In an emergency situation you don't have time to look for the brake or clutch pedal....it must happen by instinct. Practice, practice, practice...before you tackle challenges.
   / Can all tractors flip over easy? #25
We have owned 8N and 9N's,easy to get hurt on one;gear drive and have to push in clutch.Got rid of them and went to HST tractors which are much safer,IMHO and have roll bars.
We had a neighbor killed on one trying to pull out a stuck pick-up loaded with wood.Flipped over backwards and pinned her with the steering wheel.It can happen very fast.
   / Can all tractors flip over easy? #26
...and NEVER chain a log to a drive wheel to get Unstuck....
   / Can all tractors flip over easy? #27
   / Can all tractors flip over easy? #28
Have you ever heard of someone having a job called a burger roller?
:unsure:
   / Can all tractors flip over easy? #29
No they are not.
Yes they are. It’s a lot easier to tip a triangle on it’s side VS a rectangle due to the center of gravity being closer to an edge of the connecting lines. It’s been discussed and proven many times here on TBN over the decades.
   / Can all tractors flip over easy? #30
1297 (A58374)
1297 (A58374)
John Deere 4510 (A53317)
John Deere 4510...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
