Can a SA cylinder be used with float
   / Can a SA cylinder be used with float #11
So all SA cylinder have some kind of one way vent built in to allow air in?
Yes. Some plow cylinders just have a weep hole behind the wiper seal, some do it other ways, but air has the get in some how.
   / Can a SA cylinder be used with float #12
A true single action cylinder has an air vent at the top on the cylinder, unless it has nitrogen, compressed air, or is spring returned. Look for a vent hole that might be stopped up with rust, crap, etc. It might take a magnifier glass to find it, but it is there. The cyl will have difficulty returning/collapsing unless the air is allowed in to the rod/cyl chamber.
   / Can a SA cylinder be used with float #13
Very nice build!!! I've got a JD4200 that came with a retro-fitted Meyer Plow from a pick-up that some one cobbled up a mount, but not nearly as 'clean' as yours, and it's a pain to remove and remount. Like your enough to rebuild mine. More picts, or comments would be an assist. Either here, or a PM. Thanks! ~Scotty
Edit- Mine currently has the lift chain with no down pressure. Can't say I really need it....~S
Mine's not going to have down pressure for now either.
You can follow this in the "build it yourself forum" there's some more pics there and I'll be adding pictures as I experiment with it.
http://www.tractorbynet.com/forums/build-yourself/157350-snow-plow-frame-mount-front.html
JB.
CURTIS ELECTRIC AIR COMPRESSOR (A51244)
CURTIS ELECTRIC...
Land Honor Quick Attach Power Rake (A50514)
Land Honor Quick...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
