Can a SA cylinder be used with float
   / Can a SA cylinder be used with float #11
So all SA cylinder have some kind of one way vent built in to allow air in?
Yes. Some plow cylinders just have a weep hole behind the wiper seal, some do it other ways, but air has the get in some how.
   / Can a SA cylinder be used with float #12
A true single action cylinder has an air vent at the top on the cylinder, unless it has nitrogen, compressed air, or is spring returned. Look for a vent hole that might be stopped up with rust, crap, etc. It might take a magnifier glass to find it, but it is there. The cyl will have difficulty returning/collapsing unless the air is allowed in to the rod/cyl chamber.
   / Can a SA cylinder be used with float #13
Very nice build!!! I've got a JD4200 that came with a retro-fitted Meyer Plow from a pick-up that some one cobbled up a mount, but not nearly as 'clean' as yours, and it's a pain to remove and remount. Like your enough to rebuild mine. More picts, or comments would be an assist. Either here, or a PM. Thanks! ~Scotty
Edit- Mine currently has the lift chain with no down pressure. Can't say I really need it....~S
Mine's not going to have down pressure for now either.
You can follow this in the "build it yourself forum" there's some more pics there and I'll be adding pictures as I experiment with it.
http://www.tractorbynet.com/forums/build-yourself/157350-snow-plow-frame-mount-front.html
JB.
King Kutter 6' 3 pt Mower (A50515)
King Kutter 6' 3...
2015 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51243)
2015 FORD F750 XL...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
RING 3 STARTS HERE @ 9:30 AM (A51244)
RING 3 STARTS HERE...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
