Can a SA cylinder be used with float
   / Can a SA cylinder be used with float #11
So all SA cylinder have some kind of one way vent built in to allow air in?
Yes. Some plow cylinders just have a weep hole behind the wiper seal, some do it other ways, but air has the get in some how.
   / Can a SA cylinder be used with float #12
A true single action cylinder has an air vent at the top on the cylinder, unless it has nitrogen, compressed air, or is spring returned. Look for a vent hole that might be stopped up with rust, crap, etc. It might take a magnifier glass to find it, but it is there. The cyl will have difficulty returning/collapsing unless the air is allowed in to the rod/cyl chamber.
   / Can a SA cylinder be used with float #13
Very nice build!!! I've got a JD4200 that came with a retro-fitted Meyer Plow from a pick-up that some one cobbled up a mount, but not nearly as 'clean' as yours, and it's a pain to remove and remount. Like your enough to rebuild mine. More picts, or comments would be an assist. Either here, or a PM. Thanks! ~Scotty
Edit- Mine currently has the lift chain with no down pressure. Can't say I really need it....~S
Mine's not going to have down pressure for now either.
You can follow this in the "build it yourself forum" there's some more pics there and I'll be adding pictures as I experiment with it.
http://www.tractorbynet.com/forums/build-yourself/157350-snow-plow-frame-mount-front.html
JB.
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
Truck Tool Box (A50774)
Truck Tool Box...
2022 BUCKEYE BMH CAR HAULER TRAILER (A52141)
2022 BUCKEYE BMH...
