3-Point Hitch Can a kubota Bx25d handle a pto post hole auger?
   / Can a kubota Bx25d handle a pto post hole auger? #1
kubota Karl
aurora
kubota bx25d
I have a kubota Bx25d and was wondering if it is powerful enough to run a post hole auger? What size auger 9 or 12 inch? Has anyone have any experience with this? I don’t want to damage the tractor.
   / Can a kubota Bx25d handle a pto post hole auger? #2
I use a 9" auger on my BX-25 with no problem. Only thing is it has no down pressure.
   / Can a kubota Bx25d handle a pto post hole auger? #3
I doubt you would damage the tractor. It would start to bog down before you could damage anything. What HP ratings are you seeing listed on post hole digger?
   / Can a kubota Bx25d handle a pto post hole auger? #4
I drilled 50 holes or so for a fence 20 years ago with a B8200. I think it was around 16-18hp, and had 150 lbs of suitcase weights on the front.
It doesn’t really take a lot of horsepower to run an auger, but if you screw it into the ground even a much larger tractor is going to fail miserably. Be sure to read up on the subject first and your BX will be fine.
   / Can a kubota Bx25d handle a pto post hole auger? #5
I have 14hp of hydraulic power on my L4060 & it runs a 12" auger fine. The hydraulic SSQA PHD is definitely a lot less powerful than the 25 PTO HP running my old 3pt PHD on my old L3200. Hydraulics have other advantages over the PTO, put available power on a CUT or SCUT isn't one of them. And you can dig holes fine with low HP if you go slower.
   / Can a kubota Bx25d handle a pto post hole auger? #6
Biggest problem you will have is it barely lifts it high enough not to drag on the ground:eek:
2022 Robex 55-9A Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2022 Robex 55-9A...
1992 Ford Explorer (A50515)
1992 Ford Explorer...
John Deere HPX Gator 4x4 Utility Cart (A50322)
John Deere HPX...
2019 John Deere 5090E (A50120)
2019 John Deere...
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
