3-Point Hitch Can a kubota Bx25d handle a pto post hole auger?
   / Can a kubota Bx25d handle a pto post hole auger? #1
kubota Karl
aurora
kubota bx25d
I have a kubota Bx25d and was wondering if it is powerful enough to run a post hole auger? What size auger 9 or 12 inch? Has anyone have any experience with this? I don’t want to damage the tractor.
   / Can a kubota Bx25d handle a pto post hole auger? #2
I use a 9" auger on my BX-25 with no problem. Only thing is it has no down pressure.
   / Can a kubota Bx25d handle a pto post hole auger? #3
I doubt you would damage the tractor. It would start to bog down before you could damage anything. What HP ratings are you seeing listed on post hole digger?
   / Can a kubota Bx25d handle a pto post hole auger? #4
I drilled 50 holes or so for a fence 20 years ago with a B8200. I think it was around 16-18hp, and had 150 lbs of suitcase weights on the front.
It doesn’t really take a lot of horsepower to run an auger, but if you screw it into the ground even a much larger tractor is going to fail miserably. Be sure to read up on the subject first and your BX will be fine.
   / Can a kubota Bx25d handle a pto post hole auger? #5
I have 14hp of hydraulic power on my L4060 & it runs a 12" auger fine. The hydraulic SSQA PHD is definitely a lot less powerful than the 25 PTO HP running my old 3pt PHD on my old L3200. Hydraulics have other advantages over the PTO, put available power on a CUT or SCUT isn't one of them. And you can dig holes fine with low HP if you go slower.
   / Can a kubota Bx25d handle a pto post hole auger? #6
Biggest problem you will have is it barely lifts it high enough not to drag on the ground:eek:
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
