Grading Can a Branson 3510 handle a 6 foot grader blade?
   / Can a Branson 3510 handle a 6 foot grader blade? #1
Felix
Crozet, Virginia
Branson 3510 4X4
Time to do a little driveway and private road work on my property. Up to now, I've used a box blade but I've been looking at a grader blade to finish up. My box blade is a 5 footer but I thought maybe I could go to a 6 foot grader blade. Think the Branson can handle it ok, or should I stick with a 5 foot length for the grader?
Any comments would be appreciated.
   / Can a Branson 3510 handle a 6 foot grader blade? #2
No problem with a 6ft blade. You have the wt. and enough hp to handle it well.
Leaddog
   / Can a Branson 3510 handle a 6 foot grader blade? #3
I run a 6' boxblade and 7' rear blade on my 35 HP tractor ( similar weight, size and power but differant brand) with no problem.
I recommend a 7' rear blade.
   / Can a Branson 3510 handle a 6 foot grader blade? #4
I've got a 6-foot tilt blade on my 3510 and have never had a problem. Gravel, snow (not much of that in Central VA), dirt, large rocks - you name it! I used the offset/tilt to keep the ditches open along our road. The tractor doesn't care - just keeps going. Got the blade at our local C'ville dealer.
TUGGER TRAILER (A55745)
TUGGER TRAILER...
43023 (A59228)
43023 (A59228)
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
1995 John Deere 7400 (A60462)
1995 John Deere...
