Grading Can a Branson 3510 handle a 6 foot grader blade?
   / Can a Branson 3510 handle a 6 foot grader blade? #1
Felix
Crozet, Virginia
Branson 3510 4X4
Time to do a little driveway and private road work on my property. Up to now, I've used a box blade but I've been looking at a grader blade to finish up. My box blade is a 5 footer but I thought maybe I could go to a 6 foot grader blade. Think the Branson can handle it ok, or should I stick with a 5 foot length for the grader?
Any comments would be appreciated.
   / Can a Branson 3510 handle a 6 foot grader blade? #2
No problem with a 6ft blade. You have the wt. and enough hp to handle it well.
Leaddog
   / Can a Branson 3510 handle a 6 foot grader blade? #3
I run a 6' boxblade and 7' rear blade on my 35 HP tractor ( similar weight, size and power but differant brand) with no problem.
I recommend a 7' rear blade.
   / Can a Branson 3510 handle a 6 foot grader blade? #4
I've got a 6-foot tilt blade on my 3510 and have never had a problem. Gravel, snow (not much of that in Central VA), dirt, large rocks - you name it! I used the offset/tilt to keep the ditches open along our road. The tractor doesn't care - just keeps going. Got the blade at our local C'ville dealer.
excavator trenching bucket- one bucket per lot (A56438)
excavator...
CAT930K (A58214)
CAT930K (A58214)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
John Deere 7410 (A53317)
John Deere 7410...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
