Camp property found, now updates.
/ Camp property found, now updates.
I think if you can maintain plowing it with your 6x6 or your 700 he left you all winter cuz you live nearby you can diy it after snowfalls. However if you let it go your hiring someone with a d8 cat to open it up lol. That drive in is a mile you have to plow? Or is there parking before the mile trek?
The parking is at the start and where these photos were taken.
/ Camp property found, now updates. #602
There's a lot for you to like about that property. Your head must be spining with ideas.
Could that 12x28 storage/workshop building be modified for tractor storage (for now)?
Barrel stoves put out the heat but are inefficient. You might want to be on the lookout for a wood stove upgrade.
So, when is the closing?
/ Camp property found, now updates. #603
If you ever decide to upgrade the solar, you might want to offer a free ArlyA B&B stay to TBN member FatJay, and pick his brain. He chronicaled an amazing solar journey for his garage +
New garage time!
/ Camp property found, now updates. #605
My ROPS is apparently 98", which is about the height of that 4066 cab. It fits great inside my hi-cube.
Personally I'd drop a hi-cube on that site for now or possibly permanently; between a locked gate a mile back and a good lock on the container your tools should be pretty safe. Maybe some caltrops on the road, too, just remember to pick them up next time you come through...
If I was going to drive a cab into mine, I'd make sure the approach is mostly at-grade though; mine has a brief gravel ramp going up to the door which may make a cab's clearance a bit dicey because of the tilting.
FWIW, I got a one-trip 40' hi-cube with doors at both ends. Makes access to the far end trivial and easy to see without extra light during the day, plus plenty of ventillation. Mine is a light tan color which keeps cool even in 50% summer sun; I've been in dark green and dark brown containers and even in morning sun they're saunas.
/ Camp property found, now updates. #606
Container rain, literally, be watchful for, they trap so much humidity even with those little side vents I bought and ran solar fans on the inside mounted by vents one drawing air in the other expelling it. Works pretty good granted this is a 20' container. If it was a forty footer id buy more solar fans and subsequent panels I mount on the edges near the old lifting points so it doesn't penetrate the container. My 20 footer like most are probably the most rodent proof storage I own though.
No to tractor size or very unlikely. I see used good quality wood stoves for sale on FB all the time and we did know the stoves there, were of poor quality and unsafe.. We might close in a few weeks.
We were looking at a Kabota L5740 and looking at its specs, it was to tall to fit in a high cube and at this time, no one will even drive a truck into this. Maybe after we make some improvements....
/ Camp property found, now updates. #609
I've got mine with 6"-18" of space under it - it's level on a slight grade, up on railroad ties at the corners, and there's plenty of ventilation under it. I don't have the slightest bit of moisture in it.
I have friends who have a couple 20's that were on the ground and it rained in them. I took my farm jack over and put them up on blocks, and now they're dry. Certainly there's a step up going into them, but it's worth it.
Plenty of room underneath not just for air transfer but so that predators can keep the underside clear too.
/ Camp property found, now updates. #610
Inside of a high cube should be 8'9" = 105".
I see an L5740 cab height listed as 101", though that could vary with tire type.
/ Camp property found, now updates. #611
Curious what's that existing trail to camp on soil wise. is the
trail to camp about a mile long?
/ Camp property found, now updates. #612
You won't lack for physical or mental stimulation once this is yours!
/ Camp property found, now updates. #614
Yes one mile. Little dirt n clay on rock. Lots of rock.
How much improved are you planning to make that trail to your camp?
/ Camp property found, now updates. #615
I don't suppose you're lucky enough to have a vein of gravel on the property?
/ Camp property found, now updates. #616
Maybe he can get lucky and the counties clearing ditches nearby, as long as it's not a long haul they might dump it around his trail entrance. If he Asks it's usually better than clay and sand and .maybe something to work with in certain areas of a mile stretch definitely not perfect. though.
Some of the logging road mud holes are simply the dirt was pressed out via trucks, creating a berm that retains water. So the berm needs to be cut out. Other area's are so grassy, we can't see whats there and retaining the water.. The owners had been driving out there some years ago, before the last logging operation. We looked at historical moisture level for the summer which showed 6 or 8" of extra this year.
/ Camp property found, now updates. #618
Figure on 80 acres there's probably a source to find road building material of some quality on it. Unless that's a skid trail, the co that logged it problaby put down a decent base most likely found in the area they were working or the logging trucks would get buried and have to haul super light.
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
Pallet of Forklift Safety Basket (A61567)
Pallet of Forklift...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
