Wakey
Veteran Member
- Joined
- Jul 7, 2013
- Messages
- 1,164
- Location
- Madison Georgia
- Tractor
- John Deere Z915B Zero Turn 54 Deck
I figured this would be the right place to ask. Last time I looked this up they mentioned putting a tarp on the ground and measuring the liquid off it so needless to say I just went with trial and error.
Since I'm starting anew I found what looks like a rational way to calibrate the sprayer. The meat of the video starts at the 3 minute mark.
Also, I wrote up a list based on the video to make it easier for those with limited bandwidth. The list is my instruction guide so it has info specific for my application.
What do you folks think?
Large tape measure
2 - 5 gal. buckets
3 stakes
2 flags
hammer
large measuring cup
1. Measure spray width and set flags.
2. Measure width =
3. Multiply width by .80 This is the effective spray width=
4. See Chart, use effective spray width to find travel feet. =
5. Measure travel feet and set flags.
6. Time tractor in travel feet at PTO speed and proper gear and record seconds=
7. Capture each nozzles output (independently) for the time to travel sum in seconds. Add both outputs in pints and multiply by 8 to determine gallons of water per acre.
16 ounces is a pint
8 pints is a gallon
128 ounces to a gallon
**********Chart*************
Spray Width Travel Feet
20 273
22.5 243
25 218
27.5 199
30 182
32.5 168
35 156
37.5 146
40 137
**********Chemical Quantity*************
Grazon Next HL 1.6 Pints per acre (Need 4 Gallons)
Pasturegard 10 Ounces per Acre (Need 200 Ounces or 12.5 Pints or 1.562 Gallons)
LI Surfactant 1 to 2 quarts per 100 gallons as per Grazon Label
Large tape measure
2 - 5 gal. buckets
3 stakes
2 flags
hammer
large measuring cup
2. Measure width =
16 ounces is a pint
8 pints is a gallon
20 273
22.5 243
25 218
27.5 199
30 182
32.5 168
35 156
37.5 146
40 137
