Cadplan 821 Digger
/ Cadplan 821 Digger #1
dourobob
Platinum Member
Just West of Buckhorn, Ontario, Canada
Wheel Horse 522xi
Has anyone ever built one of these things and /or seen one in operation. I have ordered a set of plans with a friend of mine and we hope to share the end product. We would be really interested in any tips or ideas about enhancements that anyone may have done - such as hydraulic stabilizers. Would you recommend the kit or get materials locally? etc.
Thanks.
Bob
/ Cadplan 821 Digger #2
Try going to this <A target="_blank" HREF=http://www.geocities.com/brutusbackhoe/>site</A> , I think that it might be what you are looking for.
/ Cadplan 821 Digger #3
Someone from the old Yahoo Homebuilt tractor stuff group named "gholler" built a beautiful 708 and had some great photos of it out there before the big erase and conversion from a club to a group. If anyone knows who "gholler" is, it would be great to get him to post those caddiger images here.
/ Cadplan 821 Digger #4
I built the smaller 628. I love it. We made a few changes to it. We covered the boom swing cylinder and foot plate with a grid to provide a flat foot support. Also to provide a nonslip surface as well as being able to hose out any debrise. some pics:http://photos.yahoo.com/bc/mrcaptainbob/lst?.dir=/dirt-digger&.view=t
Also added lights on the boom extension to light the bucket, extra hydraulic ports (in/out) for auxiliary equipment such as log splitter. The main spine was extended eight inches to provide more room between the seat and engine cover (not shown). The seat was made adjustable height wise. Three buckets were made. 15", 8" and 6". All are carried on the machine and travel with it. If I did it over, I'd build the next size up. I also would like to increase the swing from the 120 degrees to something closer to 180. A fun toy......
Thanks for the response CaptainBob. Nice looking machine. My buddy and I just received the plans yesterday and spent a great afternoon discussing the possibilities. We are in Central Ontario Canada and are having some trouble justifying the MetKit approach because of the exchange and the shipping costs. Did you start with a kit or did you fabricate all of your pieces.
I really like the idea of the light shining on the bucket. Do you have any suggestions on increasing the swing to more than 120 degrees. As I said, we are just beginning and he has a lot more shop and mechanical experience than I do so he may have already figured that one out, but another point of view is always welcomed.
Douro Bob
/ Cadplan 821 Digger #6
Jim, was this 708 mounted to a JD compact? If so, I downloaded all his pics and have them. I can send them out in a zip file if someone wants them.
/ Cadplan 821 Digger #7
That may be the one. The digger was mounted to a JD 4100. the photos showed it under construction, and finished setting in the driveway with the kids' toys, and the garage in the background. Is there a way you can attach them here, so they are available to all? Thanks!
/ Cadplan 821 Digger #8
I ordered the hydraulics from Metkit. The hose lengths, fittings, pump and cylinders were already figured out. And I couldn't beat the price. As for the metal, fabricating was almost too easy. My son-in-law worked at a fabrication shop that trashed more metal in a month than what it took for this dirt-digger. He cut and welded the main stuff. Then we hauled it to my garage for finish. I have an old Skil table saw that has a cutoff wheel for a blade. It makes quick work of even 1/2" stock. Nice with a fence and miter gage, too. The light on the boom is a halogen spot 'fog' that came from Murray's. I'll post some current pictures in the next couple days showing the finished product....
/ Cadplan 821 Digger #11
Really nice work. Where did you get the hydraulic valve and the engine/hydraulic pump?
doh! I just went back and double-checked where you already answered that. Sorry. Never the less, it is a great looking tool
/ Cadplan 821 Digger #12
It's a tool to me. My wife says it's just another toy. HUMPH! Anyway...it did quick work yankin' some 3" roots from her new garden area! It's a good machine for it's size. Still wish I'd have gone up one size. (But then, I'd probably wish I'd have gone up one size anyway....).
/ Cadplan 821 Digger #13
<<If I did it over, I'd build the next size up. I also would like to increase the swing from the 120 degrees to something closer to 180. >>
I wonder if the fixed stabilizer design limits the swing arc. Not from a clearance standpoint, but from a working/clamping/stability standpoint. Any guesses?
/ Cadplan 821 Digger #14
The 180 degree would probably be a bit excessive for the frame and horizontal arms of the stabilizer. It would sure put 100% of any loading on all the structure for that side. Another plate would be needed on the ground pad. One that would 'fight' the bucket in that direction. I find that the plates that sink in the ground should be deeper than what was in the original plans. They're only 4" I think. That's deep enough to let them slide through the sod layer. Doesn't give enough 'traction'. I'll be making some changes to the whole machine somewhere near the end of the year. Maybe a winter project. Still too busy using it right now. Just added three pics the aother day. Needed to remove a small infested willow tree. The 628 sure was up to this job.
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
1994 Aeromax Semi Truck (A66285)
1994 Aeromax Semi...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
FIFTH WHEEL ATTACHMENT PLATE (A65643)
FIFTH WHEEL...
