Cab owners - How well does your A/C work?
   / Cab owners - How well does your A/C work? #41
FWIW, I've gone through 3 (now on my 4th) A/C compressor on a new Kioti DK5310SE that I bought just under a year ago (located in middle Georgia, so we get a bit of heat / humidity here).
All replacements were done under warranty and while the current condenser has been flawless with much more time on the clock than the others that failed, I'm still hesitant that I'm in the clear just yet ... I won't go into detail, but I suspect that some of the replacements weren't done entirely to every spec required....
With the above said, I'll also say that the A/C unit in the DK5310SE is a beast, I can't run it past the level 2 fan setting on a warm day for more than 30 mins without freezing certain lower anatomy; Even during 100°+ temps (un-tinted cab glass), I still couldn't keep the fan setting on 3 for too long before shivering set in... I'm honestly not joking, it's a damn-cold A/C unit .... but fingers crossed that this one doesn't crap the bed as I approach 200hrs and require another warranty replacement 🤞🤞🤞.
Maybe the 4th time is the charm! 😎
   / Cab owners - How well does your A/C work? #42
Maybe they are installing the wrong compressor part number and it’s too big for your tractor?
   / Cab owners - How well does your A/C work? #43
L6060 on a 90deg day, after cooling the cab, I need to turn it down to 2 out of 4.
   / Cab owners - How well does your A/C work? #44
On my tractors the Kioti has the coldest system, then the New Holland, then the Branson.
Over on the farm the older Deeres are hit n miss as to how well they work, the IH Magnums do well most of the time. The IH Puma and the NH 8050 are both very good.
   / Cab owners - How well does your A/C work? #45
Yanmar YT235C when temp is over 100 F usually
have fan on 2 or 3 depends on much over 100 F
willy
   / Cab owners - How well does your A/C work? #46
Mine still works great, now 11 yrs in. Actually got it about the time of the Original posting on this thread...
   / Cab owners - How well does your A/C work? #47
I have two Kioti cab tractors, and you could hang meat in both of them when the AC is running...
20 BLADE DISC HARROW, 3PT (A52708)
20 BLADE DISC...
2021 CTS HRD 37LW 34 Ton T/A End Dump Trailer (A55973)
2021 CTS HRD 37LW...
2005 GMC C7500 24FT BOX TRUCK (A58017)
2005 GMC C7500...
METAL BOLT BINS (A58374)
METAL BOLT BINS...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
Universal Mount Equipment Seat W/ Headrest & Arm Rests, and Seat Belt (New/Unused) (A59225)
Universal Mount...
