Cab in progress
   / Cab in progress #11
Man,that is a really nice jod you're doing.I just bought a Laurin cab for my machine and yours looks like it is built very similar.Once I got mine and looked at it I said to myself "It really doesn't look like more than a bunch of square stock....".Also the window install is very simple,automotive glass glued to the frame work.How much time have you invested so far?Can't wait to see more pics.
   / Cab in progress
The glove fit helps alot when you weld it together on the tractor. I borrowed 4 fire blankets from a freind to keep the green paint.
tags, so far I have about 20 working hours and about 80 thinking hours. I will have tempered glass glued in when it's finished. I made the doors removeable by raising them up 2 1/2".
   / Cab in progress #13
Will the cab work as a rollover cage?
Here in Sweden it is mandatory with a rollover cage if the tractor is used by someone outside the family or comercially.
   / Cab in progress #14
DDT,
do you plan on installing a heater? during the snow days,
it would sure be great to have one.
accordionman
william l. brown
   / Cab in progress
I don't think I will get enough heat from the engine for good heat, I will try it first and see. If not I might look at 12 volt or colent heaters.
UPDATE
I got my cab done. I took it to the body shop for a paint job. He called last night, so I took the tractor and we put it on with 4 bolts, all the adhive back foam was in place, it sure looks good. Well they were claiming a snow so I hooked up the lights and flashers so I could go at 4:00 AM. we got 2". I got done by 2:00. Man it was cold. I got the glass today when I got home. A man will be here tomorrow AM to glue the glass in. You should have seen all the funny looks I got! New cab NO GLASS. Well it should be winter ready by the next snow.
I will post the finished pic's when it's complete.
   / Cab in progress
It is not complete yet but it is close.
   / Cab in progress
pic 2
   / Cab in progress
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A56857)
2019 Kubota...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A52709)
2014 VOLVO A25G...
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
golf cart (A56859)
golf cart (A56859)
