Cab Heaters
/ Cab Heaters #1
LarryG
Buffalo, New York
Kubota BX2200
Yes I know that it is July but cold weather will be here again before we realize it. I have a Curtis Cab on my BX2200 and want to install a heater. Is there anyone out there that has done this install already? Is there an install kit for this? I bought my heater from a company called Mill Supply in Ohio. It is a heater for a step van but fits perfectly on the mounting bracket in the cab. Where did you tap in with the hoses? The power supply is easy to do with all the wiring right there in the cab. Pictures would be great if possible. Thanks for any and all help in advance.
/ Cab Heaters #2
If you contact Curtis and ask them to send the install instructions for the cab heater, so you can evaluate them, I know that they will do so. They sent me the install instructions for the cab when I requested it... It is my guess that there is a take off near the water pump and the return is in the side of the block. It might take a little looking, but I am certain that you could find it.
How much did you have to pay for the truck heater? What is the model #? Could you please list the address or web site for Mill Supply? .... thanks
/ Cab Heaters #3
</font><font color="blue" class="small">( Yes I know that it is July but cold weather will be here again before we realize it. I have a Curtis Cab on my BX2200 and want to install a heater. Is there anyone out there that has done this install already? )</font>
I have one installed on my Curtis Cab. Here is a web page that will take you to several pictures of how the heater is plumbed. I put this page up last year for someone else.
Good luck!
/ Cab Heaters #4
Bob... do you remove the cab for the warm months? I have a BX22 and there is only one cab manufacturer that has a cab for it. It cost $3500, so that is out of the picture. I was thinking of getting the Curtis soft sided cab for the winter and removing it for the summer when the hoe goes back on. I don't know what will happen with the ROPS, because the BX22 ROPS is higher to accommodate the hoe seat position. One way or the other, I will need something before the snow flies..
/ Cab Heaters
I paid $102.00 for the heater from Mill Supply. That price included shipping. It was a end of the season sale type of thing. I saw it last year also at end of season for a little less but did not get it at that time. The web page is www.millsupply.com It looks a little different than the one in the picture from rbarker but is almost the same size dimensions as the one that Curtis has. I don't know the model number, but I know that it is in their Step Van catalog.
/ Cab Heaters
Thank you for the pictures. They help out a lot. I should be able to get the T fittings and such from the auto parts store or if not I know that I can get them from Mill Supply.
/ Cab Heaters #8
</font><font color="blue" class="small">( Bob... do you remove the cab for the warm months? )</font>
No I don't. It seems like it would be a fairly big job and I don't really have any reason to take it off.
</font><font color="blue" class="small">( I have a BX22 and there is only one cab manufacturer that has a cab for it. It cost $3500, so that is out of the picture. I was thinking of getting the Curtis soft sided cab for the winter and removing it for the summer when the hoe goes back on. I don't know what will happen with the ROPS, because the BX22 ROPS is higher to accommodate the hoe seat position. One way or the other, I will need something before the snow flies.. )</font>
Okay, the ROPS fits outside the cab anyway so that won't make any difference. Also, if my memory serves me correctly, the entire back panel of this cab would remove by snaps and velcro, leaving only the roof to be concerned with. Probably not the greatest set up but it might be workable if you're not of huge stature. I'll take a closer look in the morning and verify that the panel comes completely off.
/ Cab Heaters
rbarker is correct. The back panel of the Curtis cab is snapped on top and velcro along the sides and bottom. If you can fit under the top, then there would be no problem. I think that you might be farther ahead of the game to remove the cab in warmer weather to use the hoe. I leave my cab on year round but it doesn't look to be to big of a job to remove, provided you have some help to lift it. I also don't have a back hoe either.
/ Cab Heaters #10
I got the Curtis cab heater and yes you can buy the fittings you need anywhere, the one thing they include you might not think of is an inline shut off.
/ Cab Heaters #11
If you are thinking about removing your heater during the summer you might want to think about designing in quick connects for the coolant connections....just a thought
/ Cab Heaters
Sorry for taking so long to reply, I've been out of town for a couple of days. I have no plans of taking out the haeter for the summer. I leave my cab on all year and just remove the doors and windows in the summer. Thanks for the thought anyway, it might help out someone else.
/ Cab Heaters #13
Like others have said, Curtis makes a heater that is very straightforward and works great. I have one in my Curtis Cab and it keeps me toasty in the winter when snow blowing with my B2910. It's a big imrprovement from my previous set-up - - snowblowing using a B7500 with no cab. Someone else suggested putting an in-line shut-off valve in the hosing for the heater - - and I would strongly recommend that as well. I have that in my set-up and just a twist of the valve shuts off the heat to the cab in the summer, and on in the winter. You also may want to consider installing a fan. I have one in my Curtis, and find it very helpful to circulate air when the cab is being heated, and it helps to keep me cooler in the summer heat (my cab is the soft side variety, on which I can take off the doors and the back window in the summer).
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
211298 (A62131)
211298 (A62131)
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
