Cab for B2920
/ Cab for B2920 #1
gabrichter
South Dakota
2012 Kubota B2920
Ordered B2920 should be here in month. One question I have is is there a reasonable/economical cab for this unit for winter work just to keep the cold wind and snow off me. I would want to take on and off easily so not a hard permanent cab.
/ Cab for B2920 #2
You will find all sorts of threads on TBN on ways people have found to keep out of the wind, from inexpensive golf cart covers with homemade frames all the way to purchasing a near factory cabs like the one I and many others have added. The answer will come from your ability to do the work, the amount you want to spend and the time you want to spend doing it. Cheap, like under $500 cheap will involve a little creativity and a little elbow grease.
/ Cab for B2920 #3
Unfortunately, Original Tractor Cab Co. only makes an economical cab for the BX series, not the B-Series. Too bad, since OTC provides excellent customer support and that option would have been the best price/performance as it's easy to install and remove.
There's a few other commercially available cabs that will fit the Bxx20 series that you can look at (some of them are not very cheap though):
Manufacturer Unknown Soft-sided Cabs - $1, 245 and $1600 (Note: Some of these cabs require the ROPS Fiberglass Canopy option to already be installed. In addition, several dealers sell this brand of side-sided tractor cab for around the same price, just Google for more.)
Curtis Industries WorkPro Bxx20 soft-sided cab - $2,750 (Note: The rear hard panel kit doesn't work with the backhoe option.)
Sims Cab Depot Yukon Hard-sided Cab - $3,255 (Note: Includes one hard-sided door, one fixed side panel, hard-sided removal rear window, and flat windshield.)
Sims Cab Depot Indy Hard-sided Cab - $4,062 (Note: Includes two hard-sided doors, hard-sided removal rear window, and curved windshield)
Tektite Kubota B2320 Series Cab - $4,700 (Note: One piece deluxe cab.)
Laurin Eclipse Cab - $5,566 (EL), $6,116 (ES), and $7,784 (EX) (Note: One piece deluxe cab. Comes in three different configurations.)
There's a number of European cabs available as well (such as this one for $4,568), but I don't know if they're imported into the US by any dealers.
Out of that list, even though I went with the Sims Indy cab for my B2620, if I was trying get something good enough to stay dry - I'd definitely go with the Curtis Cab for the money (plus it's made right down the road from me in Worcester, MA.)
And if I had to do it all over again, I'd probably just buy a B3000 with Factory Cab and forget about aftermarket tractor cab options all together! :)
Good luck!
/ Cab for B2920 #4
My son picked up a 4 wheeler cab at a yard sale for $20. I believe it normally goes for about $100, but even at that price, its a small fraction of a real hard cab. It fits under the ropes but is high enough that it's above my head when I'm sitting in the drivers seat. The soft cab has a internal round frame that is threaded through sleeves and holds the cab rigid. The front of it rests on the hood of the bota unless I'm using the FEL. I put some pipe insulation over that so that it would not scratch up the hood. It's definitely warmer when I'm in it, probably from my body heat, blocks the wind and keeps the snow off me. A few bungies keeps it held down.
Something like this:
4 Wheeler Enclosure for Sale
Once I'm finished with the snow season, I take the frame apart, unthread it from the sleeves and it goes into a box for storage until the next winter.
I have a B2920.
/ Cab for B2920 #5
Try covermytractor.com. You will need a fiberglass or plastic sun shade to mount to. Reasonable. Good luck!
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2006 GMC W4500 10ft Box Truck (A61573)
2006 GMC W4500...
LANPRIDE FSP700 POLY SPIN SPREADER (A64280)
LANPRIDE FSP700...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61573)
1987 International...
Caterpillar CP-563/CS-563 Parts and Service Manuals (A63117)
Caterpillar...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
