BX80 Series Announced!
/ BX80 Series Announced! #42
Hello,
I have been a long time lurker on this forum while on the hunt for my first SCUT. I thought I had my mind made up until Kubota announced the new BX80 series which may delay my purchase. I have been a bit frustrated on the lack of information released about this new product line. I decided to join the forum to share a link I found with a bit of googling, however I cant post it until I have 5 replies as I am a new member.
Hope this helps answer questions for folks.
/ BX80 Series Announced! #45
Thanks zski128! This is my first post been lurking for awhile. I am in the same boat as you. I was going to pull the trigger on a 2370 w/ FEL and 54" deck this weekend but I'm also considering waiting. I wish I knew how much more I may pay though. Also a delivery date would be helpful too.
Ryan
/ BX80 Series Announced! #47
The loader has changed from an LA243 to an LA340 or LA344. If this is the usual KG capacity, that is a major loader lift upgrade. See photo below.
Bruce
Kubota has recently changed the way they rate Loaders. The good more realistic old way was either lift at bucket center or 500mm forward of Pins.
The way Kubota rates loaders now is to rate at the pins like most everyone else does. (Does not make it right.)
/ BX80 Series Announced! #48
Nope. The Spec. sheet for the new BX23 still gives both, and there is NO improvement in the lift capacity.
OLD BX25: 745 lbs. lift at the pivot pin, and 518 lbs. at 500 mm forward
NEW BX23: 739 lbs. lift at the pivot pin, and 509 lbs. at 500 mm forward
BUT, for the BX23S with the "Quick Attach" on the FEL: 613 lbs. at the pivot pin, and 423 lbs. at 500 mm forward - MAJOR BUMMER! :thumbdown:
I'll pass, and stick with my BX25, thank you.
/ BX80 Series Announced! #49
That's the reason I went with Jery's QA. The new SSQA is way to heavy for these small tractors. Not that they can't handle it, but when capacities are already below 800#, EVERY little bit means a lot. Just look at the Kubota BX fork rating... 300#. Really?
/ BX80 Series Announced! #50
I would just be using this thing around the house. I cant imagine I would be lifting anything over 600lbs, I dont know maybe I will. What does a load of top soil weigh? What are you guys lifting that is so heavy? I look at the BX models as an oversized ride on not an industrial tractor. Thats what the B models are for.
/ BX80 Series Announced! #51
Well, that's a downer...other than that, it looks like the new BX is going to be a killer machine. Ergonomics are finally where the should have been, years ago.
/ BX80 Series Announced! #53
That new rear 3pt quick hitch is pretty interesting.
/ BX80 Series Announced! #55
/ BX80 Series Announced! #56
Good solution, robertm - will have to check it out for my 2009 BX25.
/ BX80 Series Announced! #57
If that's the case, then the new BX23 is for you - it has a great set of new features, including some nifty new quick attachment and detachment features (front andback).
/ BX80 Series Announced! #58
That was me doing the BX weightlifting test. Did you notice that the full height lift was about the same as BX specs? My 604 lbs was between those figures. Placement wasn't precise. but was between pins and 500 mm forward.
Post 48:
Bruce
/ BX80 Series Announced! #59
Disappointed to hear nothing of position control. JD returned position control to their SCUTs, and I expected Kubota to do so as well when they introduced the replacement for the BX series.
I will not buy any tractor, even a SCUT without position control, which is one of the reasons why I have never found anything to replace my 1994 B1750HST. Bi-Speed turn is another reason but not nearly as important as position control and the terrain following deck.
SDT
Case skid steer wheels and tires (A63689)
Case skid steer...
2007 Roadmaster Camelot Monaco Motor Home (A62613)
2007 Roadmaster...
3148 (A63117)
3148 (A63117)
TRAILER MOUNTED LIGHT PLANT WITH FUEL CELL (A65643)
TRAILER MOUNTED...
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
