BX25D rolls some after letting off? No ....to brake on left
   / BX25D rolls some after letting off? No ....to brake on left #1
JOHNTHOMAS
Super Member
Somerset, Ky
F2690 4WD RTV X1140 MX5400 HST ZD1211
Will came down yesterday to pick up plow. Used the BX25D to get it out of my storage building the plow was behind a 4' high stack of 3'x3' carpet squares. I lifted it with a tie down strap and got it out. Let it hang in front so Will would be sure he was at the right location. He did OK for a Pittsburg guy. He, Gary Cromer and I loaded it in his truck, talked a bit and he took off to Barlows.
2 problems. My BX25D rolls on a bit when I let off the go pedal which no other Kubota ones with HST have done previously and I've had a few to compare to. When I press brake it doesn't stop.......brake isn't there...they moved to wrong (left) side. Never used brakes other than to lock when getting off before. Didn't have to since letting off pedal stopped it. Now for close work like lifting a plow hanging off the front bucket into someones truck I needed precise control. Had to keep left foot on brake and right foot on go pedal. Didn't like.
Does your BX25D stop immediately after pedal released or keep rolling a bit?
   / BX25D rolls some after letting off? No ....to brake on left #2
My B3200 will roll a little if it's on a slope. And I agree with you on the pedal arrangements, kind of awkward to use the brakes as they are on the same side as the hydro pedal.
I got into a bit of a disagreement with my salesman when I bought the unit, after we had it a couple weeks I discovered that the latch that locks the brake pedal (parking brake) wouldn't lock. Basically he told me 'you don't need a parking brake on a HST tractor'. Are you sure about that? I kinda like to make sure a tractor won't move if I have to get off and get in front/behind/under it for some reason. He was no longer employed there shortly afterwards, and I fixed the latch myself.
Nope, I liked the brake on the right side with the hydro pedal but that's what I've gotten used to. I'll eventually adapt to the brake on left side and the lock for the brake on the new BX25D is a small pedal on the floor instead of the lever on the dash. Another getting used to deal which I'll like better once I adapt.
My BX25D does a slight continuing forward on level ground when I let off, not going down hill.
BX25D owners, where are you? Does your BX25D stop immediately with pedal release or go a slight bit?
   / BX25D rolls some after letting off? No ....to brake on left #4
Every hydro tractor I have owned (3) has stopped immediately when you let off of the pedal. In fact most will throw you through the "windshield" if you jerk your foot off the the pedal immediately. Sure they will "drift" if pointed downhill as the pressure bleeds off. But even downhill my Kioti will come to a complete stop when you let off of the pedal. As for needing a parking brake, You bet you need a parking brake. When the pressure bleeds down, your tractor will take off eventually downhill all by itself. I have never operated a BX25D, but I don't see any reason it should not operate the same. In fact I seem to remember that some of the BX's seemed to have a rather harsh stop when you removed your foot from the pedal and this was considered a negative feature.
   / BX25D rolls some after letting off? No ....to brake on left #5
Sounds like it may need some adjustment in the linkage or valve? Like the pedal isn't centered.
   / BX25D rolls some after letting off? No ....to brake on left #6
ditto-- you may need to give the locknut a couple clockwise turns that is under the tractor near the HST. Follow the hst pedal linkage to the rear and move it back and forth till you see the vertical spring above the locknut I mentioned.
   / BX25D rolls some after letting off? No ....to brake on left #7
Wasn't there another thread about this recently? Sure sticks in the back of my head... Seem to remember hearing that the newer BX models are a little different than before.
Still seeking input from BX25D owners. Where are you?
Every hydro tractor I have owned (3) has stopped immediately when you let off of the pedal. In fact most will throw you through the "windshield" if you jerk your foot off the the pedal immediately. Sure they will "drift" if pointed downhill as the pressure bleeds off. But even downhill my Kioti will come to a complete stop when you let off of the pedal. As for needing a parking brake, You bet you need a parking brake. When the pressure bleeds down, your tractor will take off eventually downhill all by itself. I have never operated a BX25D, but I don't see any reason it should not operate the same. In fact I seem to remember that some of the BX's (Owned one the BX2350 and got rid of it pretty quick and it was the only one of 16 different HSTs that I've owned, all Kubotas, that did this. My RTV1140 will if I don't ease off of the pedal Bseemed to have a rather harsh stop when you removed your foot from the pedal and this was considered a negative feature. It was a negative factor to me and I got rid of it and got some compensation for doing so
There have been slight differences between each Kubota I've owned with some aspects being a part of the year and the model. That's why I was asking for BX25 owners to respond. I want to know how their BX25D responds.
   / BX25D rolls some after letting off? No ....to brake on left #10
My 2014 BX25D has a little roll to it also. My MX5100 does not, it stops and sits still, where as the BX25D will just edge forward a wee little bit, more so with so weight on it. Bumped the garden gate the first time because I was not expecting it. Now I am used to it and don't really notice it much but it did take a little getting used to.
   / BX25D rolls some after letting off? No ....to brake on left #11
I'm not a BX25D owner, but I seem to recall reading a few times that the pedal requires some grease to get it to return to center properly.
   / BX25D rolls some after letting off? No ....to brake on left #12
Is it possible that the loader valve has priority over the go pedal? ....I seem to recall a similar experiences when using my B1700 FEL to move a 6 cyl truck engine a few years back. The tractor always came to an abrupt stop when letting off the go pedal but when moving the heavy engine suspended from a chain, I recall having to do the 2 feet shuffle. My new B2650 has the brake pedals correctly situated on the left side of platform.
Thanks. Any more BX25D owners with a response?
It's doing it with nothing on/in the bucket. Clutch pedals are on left side and brake pedals are on right side to be right especially with HST and after being on right for 11 years and over 10 tractors.:)
   / BX25D rolls some after letting off? No ....to brake on left #15
I really notice it when I am on a steep hill, I have to hold the brakes or it will roll. With the other machines I could be on most of my hills (all but the steepest) and and stop dead just by releasing the pedal.
John - as for the brakes - I get them mixed up time from time. Especially when i am using both machines and jumping back and forth. Im sure it is comically at times if the wife or kids are watching.....
   / BX25D rolls some after letting off? No ....to brake on left #16
There is no clutch pedal on my B2650HSDC....Go pedal on right and brakes are on the left, so operator operates the go pedal with right foot and left foot does the brake and if the two brake pedals are unlocked, the individual brakes are available for steering assistance...like the old Farmal Super C we used to
have. ..And I thought it wash loading something heavy at the time....Guess I gotta clean my glasses...MY Apologies.
   / BX25D rolls some after letting off? No ....to brake on left #17
My BX 25 non D doesn't stop as well as my BX 2200 did when using just the hydro. I have gotten used to it now and don't really notice but when you mentioned it I remembered being concerned when I first got the new tractor.
Sent from my iPad using TractorByNet
   / BX25D rolls some after letting off? No ....to brake on left #18
Sorry JT, took me awhile to get to this with family xmas parties and all. Mine stops pretty much immediately. In low gear it is fairly gentle. In high gear it stops too quick for my taste (with a jerk).
I thought you had a BX25 for a few years.:confused: Did you trade/buy another one of the new 25Ds that just came out? How long have you had it?
   / BX25D rolls some after letting off? No ....to brake on left #20
Op;
To clear this up-for me...
Is it a problem creeping when letting off the HST
Or a problem when tractor is already stopped?
You talk about both therefore it leads me to believe that you have an issue in both scenario's.
Thanks
Sent from my iPhone 5s 64Gb using TractorByNet
2007 Nissan Frontier SE Crew Cab Pickup Truck (A59230)
2007 Nissan...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2022 CATERPILLAR PM622 COLD PLANER (A60429)
2022 CATERPILLAR...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
