BX25D Bucket Movement
   / BX25D Bucket Movement #1
willidav
Woodbridge
kubota L3902
Is it normal to have no empty bucket movement unless the tractor is up to about 2000+ RPM? I understand you should run it at around 3200 RPM when in use, but I was surprised there is no apparent power at all below 2000 and was wondering if that is indicative of another issue.
   / BX25D Bucket Movement #2
You should definitely be able to move the bucket at 2000 RPM, and in fact even at 1500 RPM. Better check it out with the dealer.
   / BX25D Bucket Movement #3
Is the BX25 like the other BX models were this is a single pump feeding a priority flow control valve? If yes could be the priority valve is malfunctioning
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2019 John Deere TX Gator Utility Cart (A50322)
2019 John Deere TX...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
