BX25D Bucket Movement
/ BX25D Bucket Movement #1
willidav
Woodbridge
kubota L3902
Is it normal to have no empty bucket movement unless the tractor is up to about 2000+ RPM? I understand you should run it at around 3200 RPM when in use, but I was surprised there is no apparent power at all below 2000 and was wondering if that is indicative of another issue.
/ BX25D Bucket Movement #2
You should definitely be able to move the bucket at 2000 RPM, and in fact even at 1500 RPM. Better check it out with the dealer.
/ BX25D Bucket Movement #3
Is the BX25 like the other BX models were this is a single pump feeding a priority flow control valve? If yes could be the priority valve is malfunctioning
