BX25 ROPS
/ BX25 ROPS #1
stuarth
Northern Ohio
Kubota BX2670
Anyone have a way to eliminate the ROPS on a BX25 and still support the seat when its turned backwards, a place to mount the lights and also a way to cover up where the two mounting plates go with the four bolts?
/ BX25 ROPS #2
Why would you want to remove rops completely? I am not even gonna discuss the legality part in event of rollover.
As for the lights, how in the world are you gonna mount lights up high where it should be? :2cents:
/ BX25 ROPS #3
QUOTE]
My rops (top part) is alwasy removed until the BH is on. ROPS have there place but at times, not needed.
/ BX25 ROPS
My lights are low, down by the fender and I am on level gound and its never leaving my home. When it does go I will put the ROPS back on. Eighth tractor and only the third with ROPS.
/ BX25 ROPS #5
stuarth - I'm also contemplating removing the ROPS on my BX2350. Like you, this is my 8th tractor and the only one with roll over protection. I have level ground and a greenhouse with low clearance that the tractor needs to work in. I've had it off, but reinstalled it until I could get around to fabricating brackets for the hazard lights. My plan is to make a square plate that will go over the same bolt holes, and have some standoffs to hold the lights. I'm probably going to tip the lights on their side so they are also less obtrusive.
Remember to keep in mind, these tractors are much lighter than older machines. The BX tractors will tip pretty easily if the bucket isn't loaded evenly.
Good luck!
/ BX25 ROPS
I would do the same, but mine also has a rod as part of the ROPS that the seat lock's onto when it's turned around facing backwards while using the backhoe...
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
36" X 12' ADS DRAINAGE PIPE (A64281)
36" X 12' ADS...
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
