BX25 GrappleOmatic
/ BX25 GrappleOmatic
I have been getting a lot of requests for costs. I have not been keeping track of
costs. It is fair to say I am into this somewhere around $1K. Here is a
pretty comprehensive list of materials for you to cost;
Again, DO YOUR HOMEWORK, CHECK MY DIMENSIONS, PRETEND THIS IS ALL WRONG before doing anything.
VERIFY I have done all this right and that
you are not killing a warranty or a tractor, be safe, keep all people clear
of machine at all times. VERIFY my info is right! Relieve pressure off hydraulic
lines before opening them, be SAFE.
MAJOR COMPONENETS
1- Fasse Diverter valve #302-666 w/ Extension Cable
1- Fasse #PBGRIP, W/ Handle Adaptor
1- Greens-Machine Grapple (The Thumb) assembly complete (There Smallest)
GRAPPLE MOUNT TO ANGLE IRON
1- 3.5" x 3.5' x .25"Thick X 46.375" Metal Angle Iron
2- Metal Angle Iron Hand Scribbed triangular angle iron filler ends
4- Hex Bolts 5/8"-16 X 2"
4- Washer 5/8" Bolt
4- Nuts 5/8"-16
MISC.
2- Rattle Can Spray Paint Kubota Newstyle
1- Rattle Can Spray Paint Gloss Black
2'- 3/4" ID Convoluted Tube
10'- 1/4" ID Convoluted Tube
Zip Ties
1- 1/2" Type "L" Copper x about 2" long
2- Electrical Crimp connectors, blue x BX25 battery bolt diameter.
FASSE VALVE MOUNT
2- 4"OD x .25" wall x 1"long DOM Tube
1- 5.75" Long x 3.25"OD wide x 1.5"OD Tall x .10" metal channel
2- 5/16" x 3.25" Hex Bolts
4- 5/16" Heavy AN Washer
2- 5/16" Nyloc Nuts
4- AA-092A "L" Bracket
2- 1/4-20 x 1" hex Bolts
2- 1/4-20 Nyloc Nuts
2- 2" Hinge (Irwindale, CA store)
FASSE VALVE FITTINGS
1- -8 ORB x -6 MJIC Straight fitting (Port P1 on Fasse valve)
3- -8 ORB x -6 MJIC 90 Degree fitting (Ports P2, C1, C4 on Fasse valve)
2- -8 ORB x -6 MJIC 45 Degree fitting (Ports c2, c3 on Fasse valve)
1- 1/4" MNPT x -6 MJIC 90 Degree Fitting (Top of Curl Cylinder)
2- 3/8" MNPT x -6 MJIC 90 Degree Fitting (Grapple Cylinder )
8- -6FJIC x 1/4" ID Hydraulic Hose crimp fittings (Hoses)
Hose dimensions End to End overall total lengths;
15"
21.5"
54.75"
63.5"
MISC. NOTES
Disconnect both hoses from existing curl cylinder,
Plumb the OE hose w/ the factory 90 degree crimped hose fitting on it to P1,
Plumb the OE hose w/ the factory straight crimped hose fitting on it to P2,
Run new hose, 15.00" long from C1 to curl cylinder top after you replace the top fitting to a 90,
Run new hose, 21.50" long from C4 to curl Cylinder bottom 90* fitting,
Run new hose, 54.75" long from C2 to grapple cylinder top,
Run new hose, 63.50" long from C3 to grapple cylinder bottom.
This could change at anytime should I modify it for any reason.
I will be making minor tweeks over time, stay tuned,
Saammmee Bat Time, Saammmee Bat Channel....
/ BX25 GrappleOmatic #123
Thanks Artisan for the summary of materials and notes. Maybe if I do this in stages I can swallow the $1K cost. You know, spread it out over a year or so and just hope I don't loose focus and not finish it. I will have to check local dealers first on that Fasse valve and replacement joystick handle. Decision, decisions. Thanks again for a super job documenting this mod with pic's and all.
/ BX25 GrappleOmatic #124
That is one of the nice things about DIY. Besides the satisfaction, You can spread the cost out over several paychecks.
hugs, Brandi
/ BX25 GrappleOmatic #125
Artisan,
That is a very nice fab. and installation.:thumbsup: Congratulations.:cool:
hugs, Brandi
Artisan,
hugs, Brandi
Thank you and all...(were watching yours still Brandi !)
And yes, you can actually buy just the mount from greens-machine and then
buy the angle iron and do a BUNCH of fab work as you save for the rest....
Just that part of it will take you a good long while!
/ BX25 GrappleOmatic #127
Its too late now - but I think you should have used metal line from fasse unit to end of curl cylinder and then rubber rest of way. your hose is moving way too much through the open space of clevis mount point.
At this point of time - I really think you need to mod up a curled sheet metal to provide a longer curve radius for less rubbing of hoses as you curl the curl and open and close the grapple. I know you said you plan to add braided hose protection sleeve, but I fear it might not be enough.
I had considered solid lines here and there but...I found a Weatherhead
T-450 for a song w/ dies so I was chompin' at the bit wanting to make some
hoses for the first time, and, when I realized that I might be able to pull off
routing the hose thru the lower curl cylinder mount I just went for it. Also
I did not want to put a lot of time into solid lines till I tested things.
Right now, the plan is to individually wrap each hose w/ nylon braided
mesh then wrap the two inside one more mesh. I think I will achieve
2 layers of mesh shielding each from from each other in attempt to
eliminate hose to hose chaffing, then another wrap to keep them together
as a unit. We'll see but at the bottom maybe I'll install 18" or so of plastic,
rounded-edge spiral for a little added protection.
I appreciate the comments.
I am shopping for wire mesh now to barely fit over the -6FJIC x -4Crimp fittings.
I just went and measured and the crimp fiting flare out to .80" so I guess
I need to find some mesh w/ that ID. Then 1.30" ID I believe will work for
the pair.
/ BX25 GrappleOmatic #129
While youre trying to double sleeve hoses over a length youll ether decide against it or choose a loose outer sleeve. Makes it sloppy and bulky for very slight gain.
larry
larry
Sounds like the voice of experience!
Trailmobile Van Trailer (A61307)
Trailmobile Van...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2013 Ford Explorer SUV (A59231)
2013 Ford Explorer...
1997 Sherman and Reilly Drum Line Puller Tensioner Trailer (A59228)
1997 Sherman and...
