Oil & Fuel BX25 first service 50HR
   / BX25 first service 50HR #12
I just got my Bro-Tek skid plate last week. I haven't installed it yet, but was so afraid of trashing the tranny fan that it was one of the first things i bought. As I'm pushing over lots of brush and saplings right now and saw some potential fan busters left standing, I thought it would be a prudent item to buy. I still have the mower mounted so I'm somewhat protected, but I'll be removing it soon to narrow the tractor working width for use with the loader/backhoe.
   / BX25 first service 50HR #13
Sure wish SUDT oil was available in Australia cause i would use it . Due to warm climate 30f to 100f i guess Kubota reckons UDT is sufficient .
You'll actually find it's because they can't be bothered ; just like all the
accessories they don't keep either . Use JD 10w30 HyGard trans oil.
That's the closest to SUDT . UDT is re packaged 20w and not the factory
recommended multiblend. The revs go 250rpm faster with the correct oil.
The quicker flow rate is important for small HST pumps , which is why JD
source the correct stuff , but then they give a proper warranty too ; not like
the Kubota Aus. tossers ! I get all my non-liquid requirements sent from
CA. Most of Australia's temp isn't any different to large parts of the US , Spain ,
Africa , South America ; and they can get SUDT !
You'll also find their engine oil is base rubbish ; go to Super Cheap Auto and get
some high detergent Castrol RX super ; designed for low pressure fuel pump
/ high soot mini engines .
Have you bought spacers for the rear wheels to increase track and stability
when using the loader on a backhoe machine ?
   / BX25 first service 50HR #14
Nice looking spacers OrangeRidge! can you give any details regarding source and pricing? I chicken out at 25 degrees sideslope :D
Bruere, I assume that you did your own servicing, speaking of warranty check your warranty booklet coz mine says that the tractor has to be serviced at least once every 12 months by an authorised dealer to maintain coverage, also use genuine parts ... fluids can be Kubota or equivalent spec ... that's mine understanding anyway
   / BX25 first service 50HR #15
USD234 delivered ( USPS 7 day air / sign for and tracked )
Wheel Spacers for Kubota B and Kubota L Series Tractors, Kubota BX Series Tractors, Kubota RTV, John Deere XUV Gator HPX, Cub Cadet Tractors, Polaris Ranger 6x6 Tracks
Christian Hansen will make whatever width you want. I went with 2" and
a 1.5" ( 54" MMM restricts you ... ) .. or 2@2" for 60"MMM
He supplies 10 original Kubota bolts and fixing bolt aswell.
Pay with PayPal and it's currently Aus$225.
The Yanks have very cheap freight . Product from Canada was USD120
freight !
   / BX25 first service 50HR #16
Thanks! that's a very good price ... will act while the dollar is strong :thumbsup:
   / BX25 first service 50HR #17
You'll get a much improved cut with the wider rears . Less flapping
from side to side of the outer blades --- the Mohican effect , as I call it !
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
Push Mower (A55973)
Push Mower (A55973)
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
GMC 2500HD 4wd Service Truck (A55315)
GMC 2500HD 4wd...
2015 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-65...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
