BX25(2014) neutral switch help
/ BX25(2014) neutral switch help #1
PA-Kubota
Apollo PA
2008 BX2350
I need to wiggle pedal several times to get engine to crank. Switch isn't loose and adjustment is OK... that said any tips/tricks to replacement?
thanks
/ BX25(2014) neutral switch help #2
thanks
I'd guess there is minor bind in the linkage preventing the pedal from returning to neutral. Cross Shaft or Treadle mount are likely culprits.
No help on replacing switch, I have 4500+ hours on my bx2200 and that switch has never failed. Plenty of other things wore out...
  • Good Post
Reactions: JWR
/ BX25(2014) neutral switch help #3
If you can get to the switch try spraying some contact cleaner into it - like along the little moving shaft. Work it a few times. This may or may not solve your problem.
/ BX25(2014) neutral switch help #4
Isn't there a grease fitting under the floor mat for the travel pedal?
Good Luck!
/ BX25(2014) neutral switch help #5
I've replaced the switch twice on my BX22 over the nearly 22 years I've owned it...weather does get to them. It's not a super difficult job.
Linkage is OK and pushes switch fully... just haven't got around to replacing switch yet!
/ BX25(2014) neutral switch help #7
Eagle1... You have 4,500 hours on your bx2200... thats amazing but then again I guess not. I've seen some farm tractors with a lot.
/ BX25(2014) neutral switch help #8
Hard hours and it's taken everything I did to it. Still use it almost daily, after 24 years it deserves some respect. Never been to dealer for anything in that time.
It did finally get a bigger brother to take some of the heavier loads.
/ BX25(2014) neutral switch help #9
On our HST, the treadle pedal controls the HST pump, but also has a control cable going to a drum which advances the throttle so you get more HP as the treadle pedal is advanced. That control cable broke, which meant that when the pedal was advanced, the RPM stayed at idle. The cable looked OK, but wasn't pulling on the drum because it had broken inside the cable cover. Simple job to fix.
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
2018 John Deere Z950M Zero Turn (A63116)
2018 John Deere...
2013 JLG 10054 SKYTRAK TELEHANDLER (A63569)
2013 JLG 10054...
2004 VOLVO  L50D WHEEL LOADER (A63569)
2004 VOLVO L50D...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
