Bx24 or Equivalent: Strategy
/ Bx24 or Equivalent: Strategy #1
Hotwheels
Rescue, Northern California
Kubota BX24, RTV900-Worksite
I have about 7 acres that is on a slope. Maybe 5 acres is workable. I have decided I need a tractor and my wife wants a backhoe attachment to dig out bowling ball and basketball plus size rocks to relocate for landscaping. A lot of the area needs some leveling or filling before I can do more than field mowing. A TLB like th Kubota BX24 the MF GC2310 or equivalent seems like enough tractor. I did find a lightly used Mahindra 2615 for sale near me with the FEL, Box scrapper, and roughcut mower that is attractively priced. I am tempted to buy it and add a woods or similar BH when the need arises. In the mean time the FEL, mower, and roughcut would keep me busy.
However, my wife really likes the Kubota BX24 and she favors buying it. Her thoughts are that we can use it to do the landscaping work over the next 2-3 years and then sell it and buy something to do the finish mowing and other tasks we no longer wish to do by hand. Given the apparent resale value of the Kubotas, it seems like good thinking.
If we bought the used Mahindra or anything else used, it is not likely to have the same resale value, but it seems to be more tractor to start with and maybe in the long run, less costly, even if we did add a backhoe.
In rough numners, the BX24 is about 2k more than the used Mahindra with the attachments. Shoud I even be thinking about the BX24 as a comparison to the Mahindra?
/ Bx24 or Equivalent: Strategy #2
Is the Kubota only 2k more with the backhoe and FEL??? If so, that is the better buy. A 4 or 5 foot rotary cutter can be bought for under $600 and the box blade would be about $350. I'm thinking you mean the Kubota is 2k more without the TLB package.
/ Bx24 or Equivalent: Strategy #4
Hotwheels: Let me get this straight. Your wife has endorsed the purchase of a backhoe and you are hesitating?? A hoe is a big bucks purchase. Get it now while you can. All the other implements are relatively cheap. Blades, rakes, boxscrapes, log splitters, pallet forks, etc are all under $700 each.
I just ordered a backhoe. My only regret is not ordering the backhoe 5 months ago when I bought the tractor. Now I will have to haul the tractor 20 miles to the dealer and wait a week until I can go pick it back up.
/ Bx24 or Equivalent: Strategy #5
Sounds like the BX 24 or Massey 2310 will do everything you need it to, plus they already have the backhoe. Once you get one of these and start finish mowing with it as well, you'll never sell it.
In 2-3 years it will be like an old pal that can help you dig or spread mulch etc. and still cut the lawn.
In round numbers the BX24 is about 16k and the Mahindra about 14k with the implements. The BX24 is the package including the FEL and the backhoe. My wife likes the idea of the backhoe and her only hesitation is if the tractor has enough power overall --- I think it does.
My guess is also that after a couple years the tractor would have a name, maybe its own bedroom, and probably never leave. But, if we should decide that we WANT to sell it, then I assume the resale value on a Kubota TLB would be strong. If we deceide to keep it, then we paid the Kubota brand premium and live with that.
I looked at the Massey Ferguson GC2310 also and it seems to have a SLIGHT edge in specifications -- wider, a little more PTO, etc... but, on specifications it would not tip me one way or the other. Have to take the spouse by to operate the backhoe on that one to see how she likes it.
The used Mahindra seems pretty nice and it has nice specifications -- it is a heavy tractor and seems to have about the same turning radius, which is important for me: Kubota BX24 is 7.5, and Mahindra 2615 7.9 GC2310 ?
I think the issue is if the BX24 has enough power -- seems like it, but our neighbors have larger tractors.
/ Bx24 or Equivalent: Strategy #7
MessickFarmEqu said:
You'll also send a good $6000+ adding a backhoe to the Mahindra.
Yes Neil, they are around that number with a bucket, subframe, mounts, hydraulics and labor to install, but remember that they are not a light duty 3-point mount. They dig 7'10" and have a reach of over 10 feet. They weigh about 1200 lbs. You are very up on the kubota line, what size BX or B gives similar features and reach? That would be helpful info.
For the thread at hand, I think the BX would do fine, but just remember that it is a subcut, not a CUT. The difference is much more than 2 HP. The Mahindra with a backhoe and loader will weigh about 4200 lbs, maybe a little more. I would think the BX would be 1500 lbs lighter? Neither good nor bad, depending on the application, but not similar.
As for resale, Mahindras resale great in northern California. I can't speak for all areas, but a used 2615 won't last a week on out lot. If you buy a used one, you have already saved some money and the odds are that it will be worth 90% of what you paid for it (used) if you sell it in a couple of years in good condition.
If the wife says get the little Kubota and it will do the job, that advice should certaintly not be ingored, but you might try both out first to make sure you are purchasing a tractor of the correct size for the job at hand.
The Kubota backhoe does not have the capacity of the Mahindra and it is lighter. Kubota lists the tractor weight as 1542 the Bx24 package as 2245. The Mahindra weighs 2458, so there is almost 1000 pounds difference in the tractors. Although the BX24 would prooably do it, the extra capacity of the Mahindra is attractive. The spouse just needs to get on a Mahindra of this size and see if it feels as comfortable as tghe BX24.
/ Bx24 or Equivalent: Strategy #9
It strikes me that the BX24 is too small for that size property. You'll be forever mowing. Its light weight severely limits what you can do with a backhoe too. I bought smaller at first. Love the machine, but regretted not buying bigger. I eventually did buy bigger. In the end, it cost me way more $$$, and now I have two tractors to store and maintain.
If your wife likes the small size and manueverability of the BX24, try a TYM T273 or T233. While not a subcut, these are just as manueverable as the BX's, way better for digging, and more HP for your 3 pt chores. Much nicer tractor, much more capable, though a few more $$$. The new TYMs are the sweetest small frame CUTs out there right now. Or for less money, look at a Kioti CK20HST too.
My advice: Don't buy that little tractor. You'll wish you had bought bigger. Of the two, unless you will absolutely sell in a few years, the Mahindra is the smartest long term purchase. Get as much hp as you can afford.
Right now I am forever weed wacking and that is getting tiring, so any mowing is would be a great long term improvement. We are trying to prepare for the future and ensure we can stay in our house as long as possible -- being able to maintain the property on our own terms is important so the tractor that has the most long term solutions for us is what we need. The larger tractor with more capacity is desirable if it can turn and manuver around trees and rocks. I have seen the Kioti and they look nice. There isn't a TYM dealer close to me, so I will probably stay with what I can get from a local dealer. Thanks for the suggestions.
/ Bx24 or Equivalent: Strategy #11
I just do not see how the bx could be "too small" for 5-7 acres. Many people maintain larger tracts of land with smaller less powerful garden tractors. It also does not sound like the backhoe will be used for major digging tasks. Just digging out some rocks and landscaping around the property.
****This is exactly the type of property and situations the bx series and equivelents were made for****.
Also the word slope was mentioned. The bx is going to be a more stable machine on sloped property as the center of balance is lower.
Now granted, "I'm definately not saying do not get a larger tractor". You can do things with a larger machine that are just not possible with a smaller machine. But the same can be true of going smaller. If you are looking at finish mowing in the future, the BX will be a much better finish mower down the road than the Mahindra will be.
To get the Mahindra and hoe you are looking at at least 4k more. Then you may still need a good mower down the road for additional k.
Me myself and I would get the smaller machine and rent a full size backhoe for a weekend here and there if you need to do some major work. A full size Backhoe will make any subcompact or compact look like a toy when it comes to digging and loader work.
Slope defines our property ... some is steep, other parts workable. We can probably mow 3-4 acres and afer some work leveling and filling, then finish mowing is what we want to do since the rough cut length long term will not be enough for us. But, we have rocks, etc... to get out of the ground and other preparation to do before we can finish mow. I suggest that we rent a large backhoe or excavator for moving any larger rocks, but the BX24 or equivalent machine would please my wife who has her heart set on using the BH to dig out rocks, stumps, and other things. For us, the larger tractor would be most useful in the short term, the smaller tractor better long term. I can't justify 2 tractors and so our needs are to have some utility tractor that can move rocks, haul dirt, flatten out bumps, and do general landscaping tasks.
We will look at some more TLBs, ones with good ergonomics, enough power, good for slopes and good manuverability to get around the rock outcroppings and trees.
Thanks for the thoughts.
/ Bx24 or Equivalent: Strategy #13
You will love the BX24........ i have had a BX23 almost 2 years and with 20 acres I look for projects.
/ Bx24 or Equivalent: Strategy #14
Test drive as many as you can, both subCut and CUT, and then you'll know what to buy. Some considerations:
  • roll bars get in the way when mowing around trees, but would save your life in a roll over.
  • Many prefer rear mount mowers to midmounts, especially on larger machines.
  • Tractor weight is paramount for digging. Lightweight machines are simply poor diggers.
  • Lift capacity and, more importantly, lift height are much less on FELs for subcuts. Many subcuts will not lift high enough to reach a pickup bed.
  • Subcuts use smaller implements, which are easier to store. But, there are fewer options available to choose from.
  • Some SubCuts offer 4 wheel steer. This is a great option that you might want to consider.
  • Money spent for 3 or 4 days of rental of a big backhoe might be enough to buy a second lawn tractor.
  • Two machines means twice the maintenance. But, then two people can work at the same time.
  • Consider how many hours you'll be spending mowing, and at what level it will be tolerable for you. I use a 54" mower on 2 acres; takes 2 hours on one of the most efficient mowers out there. I wouldn't think about mowing more than 3 acres with anything smaller than 60".
/ Bx24 or Equivalent: Strategy #15
Hotwheels, I'm another extremely happy BX23 user. Turned 700 hours this weekend. All of my 5 acres slopes to some extent too. I've often thought of a larger tractor but, not being an expert tractor man, I find doing things in smaller chunks, or slower, allows me time to think about what I'm doing and not have to re-do something I screwed up badly.
Whatever you wind up getting, enjoy!
Cheers!
/ Bx24 or Equivalent: Strategy #16
You "BX" tractors guys bring up a good point. If you are not in a hurry, a small tractor will get a tremendous amount of work accomplished. My first tractor, and I've sold more than a thousand since, was a Yanmar YM1500 2wd. It didn't have a loader, but I had a box scraper and a set of forks, plus a drag. I got so much work done on that little machine! My perspective has changed now, but there is a lot of truth to what is being said.
On the flip side, the smaller machines tend to be "first" tractors for most guys with more than an acre or two. They get good at working the machine and soon want to take a bigger bite with the loader, dig out a bigger rock, pull a wider box scraper, etc. The good news is that tractors do not depreciate like a car or truck. You can use them for a couple of years, or 10 years, and still get a good share of your money back. So if you buy too small, it does cost you to trade up later, but it isn't a real bad hit.
I went this morning before the sun became too hot to look at the Massey version of the BX24 -- nice machine too. I also looked at the Kioti CK20, but it gets more costly with a backhoe and loader than the Kubota or the Massey. it was suggested that I also look at the Mahindra 2015 that has good power and turning radius.
The dealer I spoke with suggested that it is mostly time and some terrain issues that determine tractor size. You take smaller bites, move less at a time, etc.... If I was buying the tractor for today, it would have to be a bigger one that would take less time, but I am tapering off work this year and hope to spend most of next year and those to come doing landscape work, woodworking, fishing, etc.... So, although time is an issue, it is not the same issue as it would be if I were still working full time.
I am still not completely sold on the smaller tractor, but my spouse is. I need to see the smaller Mahindra and check out the costs to equip it with a backhoe, but my guess is that it would be 3-5k more.
Thanks again for the observations and comments.
Cheers!
Homebrew -- looked at the photos and I cannot imagine needing to lift bigger rocks than shown in your pics with the "thumb" attachment. Do you have the Kubota part numbe for that :)))) Looks to be a very stout tractor for its size and should do as much as I need it to, although maybe it will take a little longer than if I had a larger machine.
/ Bx24 or Equivalent: Strategy #19
The Mahindra is definitely worth checking out, too. I could be wrong, but when I was looking at them it seemed they had higher lift capacities than other tractors their size. Little workhorse of a tractor.
I still vote for a new TLB, whether Kubota, Massey or Mahindra, than adding the backhoe to the slightly used Mahindra. Question for you guys though... any of you ever mow with that backhoe on using a MMM? How easily will he be able to mow? How easily does the backhoe come off if he wants to mow with a RFM?
Roxynoodle: People who know about the Mahindras say the 2015 and 2615 are strong machines. The specifications on the Mahindras must not tell the whole story because the BX24 looks very strong other than in weight and lift capacity.
2015 2615 BX24
weight 1973 2458, 1542
Horsepower 20 26 23
PTO 16 21.1 17.7
Width 53.5 59.4 55.1
Turning Radius 7.2 7.9 7.5
Lift capacity 1400 2205 450
Cost (TLB) 20969 22954 16000 (list prices)
It does not seem there is much dealing on Mahindras. I can buy a BX24 for 15500 plus tax and delivery. I have to add a mower later, but that would be close in cost for any of the options, or close enough for me that it is not in the decision mix. With a 4k difference, the BX24 looks very nice.
Edit
Speciication 2015 2615 BX24 GC2310 Koti ck20
weight 1973 2458 1542 1367 1993
horsepower 20 26 23 22.5 21
PTO 16 21.1 17.7 18.7 15.5
Wheelbase 53.5 59.4 55.1 57.1 57.9
turning radius 7.2 7.9 7.5 na 8
lift capacity 1400 2205 450 1190 1109
cost 20969 22954 16000 16900 ?????
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
2015 Caterpillar 430F 4x4 Extendahoe Loader Backhoe (A60352)
2015 Caterpillar...
RING 2 STARTS HERE @ 9:15 AM (A62130)
RING 2 STARTS HERE...
2022 CAN-AM BOMBARDIER LIMITED RTV (A59823)
2022 CAN-AM...
2014 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCNCPEH0EZ393232 (A61165)
2014 Chevrolet...
