BX24 Battery
   / BX24 Battery #1
cubowner
Bronze Member
Kubota BX24
I need to replace my BX24 battery. Does anybody know what generic battery will replace / fit the BX24 tractor?
   / BX24 Battery
Will try that thanks
   / BX24 Battery #4
On my 2004 BX2200 standard "24DC" Marine Deep Cycle battery fits in rack perfectly and has the correct post configuration. I assume Kubota has maintianed similar standard in newer BX. Costco (Kirkland) has best $ deal and best CCA in class at 700. Does manual show the spec?
   / BX24 Battery #5
Nope, my neighbor has a BX2200 and his battery compartment is much more forgiving on the size requirements. I'm not sure when they changed it but my BX2350 (assume the same for the BX24) has a very restrictive battery compartment and you can't barely go much bigger than the factory size which is a shame.
I just replaced mine w/ a group 26R battery from the auto parts store. Only difference was the + and - terminals were flip flopped but I was still able to make the connections.
BX2200 battery compartment;
attachment.php
BX24 (same as BX2350) battery compartment;
   / BX24 Battery #6
Hmmm, I would have thought that a deep-cycle battery was the opposite of what's required for the high-current, short-duration load to start a diesel engine.
I presume it's working OK. Did you choose it for the size only, or am i off base here? (again...)
[edit] Just checked my BX-24. A 24DC battery is much larger than the battery in my tractor. Wouldn't fit.
My battery is 8"L, 6.5"W, and 7"H.
Thanks,
Z.
   / BX24 Battery #7
I replaced the battery in my BX24 last week. I went to Costco and the closest one was about 1" longer and 1" taller. The width was about the same. It fits into the space and works just fine.
   / BX24 Battery #8
Use the numbers/letters on the current battery to cross-reference. Also, you may want to check the local battery shops in you're area (not stores like pep boys) most give competitive prices and money off for turning in the old battery.
   / BX24 Battery #9
Really? I had to get a new battery for my Expedition this fall and (O'Reilly auto) charged me $5 or $7 for a disposal fee. Crap!
   / BX24 Battery #10
Hydraulic Grapple Bucket (A47384)
Hydraulic Grapple...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
2013 Infiniti M37 Sedan (A50324)
2013 Infiniti M37...
Case SC Tractor (AS IS) (A50774)
Case SC Tractor...
2020 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2020 CATERPILLAR...
