BX24 Alternator
   / BX24 Alternator #11
I know the BX2350 has the same 40amp alternator.
   / BX24 Alternator #12
40 amps is 40 amps.
I don't see where what tractor it's on would make any difference.
L . B .
Is the 40 amp alternator output the save for the BX2350/60 and BX1850/60? Seems it wouls be. I ask because I'm in the process of wiring up two 55 watt work lights and I'm assuming I can run these off the stock alternator, which I though was 40 amps.
   / BX24 Alternator #13
I have BX24 and i am including a pic of my alternator. I found a pic on this website that shows the old dynamo alternator that looks smaller and has solid casing. perhaps you could compare yours and make an educated guess.
Thanks, I'll have a look as soon as I can get out to the shed. About 14*F here and icy. I'll be waiting for some warmer weather to finish the install (have the wires run and the switch installed) anyway. I'm pretty sure all the BX's are the same as far as the stock alternator but now I know what that dyno looks like so I'll know for sure.
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
Toro Z Master Mower (A50322)
Toro Z Master...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2019 CATERPILLAR 272D2 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
