BX24 Alternator
   / BX24 Alternator #1
treceveu
Can anyone tell me the output of the alternator supplied stock on the BX24? I can't find this spec in the owner's manual. Thanks.
   / BX24 Alternator #2
i read this in a thread a while back. seems like it's around 40 amps or so. someone will chime in with the exact number....
amp
   / BX24 Alternator #3
Stock dynamo output is approx 14 amps. Upgrade alternator is the 40A unit
   / BX24 Alternator #4
i think all the bx24 units came with the alternator. bx23 had the dynamo stock with alternator upgrade option. at least that's how i remember it....
my 24 has the alternator and i didn't order it a special way or pay extra as far as i know.
amp
   / BX24 Alternator #6
Looked in the BX24 factory workshop manual- although they show how to measure the charging current with an ammeter they never say what it should be:cool:
   / BX24 Alternator
Thanks gents. My BX 24 does indeed have the alternator, not the dynamo, so I guess the 40 amp unit is stock as per some of the replies.
   / BX24 Alternator #9
The BX24 has the 40 amp alternator standard equipment
Is the 40 amp alternator output the save for the BX2350/60 and BX1850/60? Seems it wouls be. I ask because I'm in the process of wiring up two 55 watt work lights and I'm assuming I can run these off the stock alternator, which I though was 40 amps.
   / BX24 Alternator #10
I have BX24 and i am including a pic of my alternator. I found a pic on this website that shows the old dynamo alternator that looks smaller and has solid casing. perhaps you could compare yours and make an educated guess.
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2020 Kubota Sidekick RTV-XG850 (A47384)
2020 Kubota...
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
