BX2360 Fuel filter change
   / BX2360 Fuel filter change #1
sw18x
Looking
Got a day off and I'm almost at 100 hours so...any tips or tricks for a fuel filter change on a 2360?
   / BX2360 Fuel filter change #2
The front one is straight forward. The rear one is harder to access. You'll also need to clamp off the hose in the rear to prevent diesel fuel from flowing.
Kinda like a surgeon clamping off a bleeder. :)
   / BX2360 Fuel filter change #3
I install a valve in mine on the first change so it easy thereafter.
   / BX2360 Fuel filter change #5
What sort of valve did you use?
Thanks,
Wrooster
A little 1/8" ball valve with 1/4" or 5/16" barbed ends. I think I got them at a Parker dealer.
   / BX2360 Fuel filter change #6
thake a pair off vise grip and put it on the fuel line and it want leak that what i did and its work great
   / BX2360 Fuel filter change #7
I use 2 hose clamps purchased at Sears for $15 a piece. No leaks at all during the filter swap.
   / BX2360 Fuel filter change #8
I'm sticking with the manual and going for the 500 hour replacement. Going to the trouble of filtering the fuel as it is added to the tank should give me even cleaner fuel and make it to 500 hours with no problems. And I think I'll just use the hose clamp idea when I get there because adding a shut off is just another source of leaks IMO.
   / BX2360 Fuel filter change #9
And they will not "chew" up the rubber like vice grips!
Although, Tod, I do like the valve that kevinj installed!:thumbsup:
Deano
   / BX2360 Fuel filter change #10
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
FAKE (A52472)
FAKE (A52472)
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52576)
2023 TAKE 3...
