BX2360 Fuel filter change
/ BX2360 Fuel filter change #1
sw18x
Looking
Got a day off and I'm almost at 100 hours so...any tips or tricks for a fuel filter change on a 2360?
/ BX2360 Fuel filter change #2
The front one is straight forward. The rear one is harder to access. You'll also need to clamp off the hose in the rear to prevent diesel fuel from flowing.
Kinda like a surgeon clamping off a bleeder. :)
/ BX2360 Fuel filter change #3
I install a valve in mine on the first change so it easy thereafter.
/ BX2360 Fuel filter change #5
What sort of valve did you use?
Thanks,
Wrooster
A little 1/8" ball valve with 1/4" or 5/16" barbed ends. I think I got them at a Parker dealer.
/ BX2360 Fuel filter change #6
thake a pair off vise grip and put it on the fuel line and it want leak that what i did and its work great
/ BX2360 Fuel filter change #7
I use 2 hose clamps purchased at Sears for $15 a piece. No leaks at all during the filter swap.
/ BX2360 Fuel filter change #8
I'm sticking with the manual and going for the 500 hour replacement. Going to the trouble of filtering the fuel as it is added to the tank should give me even cleaner fuel and make it to 500 hours with no problems. And I think I'll just use the hose clamp idea when I get there because adding a shut off is just another source of leaks IMO.
/ BX2360 Fuel filter change #9
And they will not "chew" up the rubber like vice grips!
Although, Tod, I do like the valve that kevinj installed!:thumbsup:
Deano
/ BX2360 Fuel filter change #10
/ BX2360 Fuel filter change #11
when I change my fuel filter, I use a sharpie and right hours and date on it. ANd I also use vise grips on the under fuel filter on my bx24
/ BX2360 Fuel filter change #12
If you are bad, this is what the first change at 5 years looks like.
CRATE OF FLANGES AN PIPING (A68842)
CRATE OF FLANGES...
AC/3 Phase Hydraulic PU w/Tank (A64912)
AC/3 Phase...
CAT 963D Cab (A68134)
PORTA POTTY (A68842)
2016 FORD F-150 (A67714)
2016 FORD F-150...
PORTA POTTY (A67714)
