BX2350D will not start when hot!
   / BX2350D will not start when hot! #1
rabbott48
2008 Kubota BX2350D
Kubota BX 2350D will not start when hot!!
   / BX2350D will not start when hot! #2
My older B1700 won't restart when hot except if I reset the glowplugs. The engine seems to cool off very quickly after shutting off.
   / BX2350D will not start when hot! #3
Can you provide any more detail? Does it turn over? etc. What have you checked thus far?
No it does not turn over. I have replaced the fuel stop Solenoid. I have check the fuses, safety switches, replaced fuel filters. When it does start it will not shut off!!
   / BX2350D will not start when hot! #5
Ignition problem? If it wont shut off maybe you have a problem with the circuit the ignition switch is on.
   / BX2350D will not start when hot! #6
Do you have a Volt-Ohm Meter (VOM)? First step is to use a VOM & spend half an hour checking the battery, starter circuits, and safety switches. I'll bet you'll find it then. If not - well, you still had to check those things first.
rScotty
Alamo SH88 88" 3pt Flail Mower (A50774)
Alamo SH88 88" 3pt...
New Holland 276 Square Baler (A50774)
New Holland 276...
John Deere 6125M (A50120)
John Deere 6125M...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
