BX2350: How Much Work Capacity?
/ BX2350: How Much Work Capacity? #1
gunpaq
Sullivan County, Pennsylvania
BX2350 Work Capacity?
How much heavy duty type work is the bx2350 capable of doing with a FEL, etc.?
Looking at one for our farm to do the lawn mowing, manure clearing from the small stables, rototilling, move feed bags and loose feed, snow removal/plowing, and running small bush hog type mower for around the fences and so on.
We run a full size cattle farm and have the other Kubota M & L series tractors for doing field work.
Will the BX2350 actually perform or is it a glorified garden tractor?
The local dealership salesman says the BX2350 will do most anything.
What is your experience?
Thank you.
/ BX2350: How Much Work Capacity? #2
I have a bx24 and have been quite impressed with the power of this unit. For what you're describing, it will handle the job. It may need a little ballast to do the heavier work effectively, espeically if you're used to the larger tractors. You won't be disappointed if you're comparing it to a previous experience with a garden tractor.
/ BX2350: How Much Work Capacity? #3
I used a couple of 20HP garden tractors before getting my BX, and there's definitely quite a difference. I agree that from what you describe, the BX sounds like it'd do just fine. But, I think it's still important to know that a BX isn't meant to compete with construction equipment, but rather a shovel and a wheel barrow. :)
/ BX2350: How Much Work Capacity? #4
It doesn't sound like you will be working in areas that require more clearance, and the BX is designed for the kind of chores you expect to complete. The B2x20 series will push harder, pull more, and hold up a little better for continuous heavy use. I would by the BX if mowing is your primary task, and the B if other things are going to make up most of it's use. The B is a little heavier, but still no heavier than many ZTR mowers. You will find that the BX needs more RPM than you are used to for loader work, etc. but they are designed for that.
/ BX2350: How Much Work Capacity? #5
I bought mine thinking it was a diesel powered glorified lawn tractor. I wanted a mower with a small loader for snow. I was very wrong. It is a downsized tractor. It mows and brush hogs fantastically.
The loader is very capable for its size. The key words "for its size". I believe it will do what you describe very well. If you have bigger machines you may feel like its slow. The hydraulics will be much slower than a larger machine. And it will only lift 500#. Other than that, it should be fine. I would not hesitate to do any of the tasks you are asking of it. The mid mount mower speed and quality ( both cut and build) rival and exceed many walk behind commercial machines I have used.
/ BX2350: How Much Work Capacity? #6
My first Kubota or any tractor was a BX2200 MMM FEL I bought 4 years ago. I thought they were a high priced mower but they are a tractor that is also a great mower. It did so much that I decided I needed the next size up so traded 3 years ago for a B7800 FEL 6'RFM which has higher ground clearance and a bit faster with jobs. Then bought a BX1500 54"MMM for wife to help me mow. Traded B for a L3240HST a few weeks ago then traded BX1500 for a BX2350 60MMM last week to do my mowing with. Have 3 acres hill side rolling terrain with rocks still to be moved and dirt to be moved. Your L and M will do anything heavy you need to do so to me the BX is what you need. They now have a 26HP BX but I did not go for it for the difference in money. Figure my L will do anything beyound the BX2350's ability.
/ BX2350: How Much Work Capacity? #7
You are a perfect candidate for a BX, having the other tractors avaliable for the heavy tasks. The BX will mow your lawn and do the "tight space" jobs for you.
Will
/ BX2350: How Much Work Capacity? #8
It is a real tractor. You will not be able to lift the heavy FEL loads that you can with your big tractor, but you can do many of the same things on a smaller scale.
A BX with a backhoe can do what any other one can, except dig effectively in the hardest of true hardpans and excavate big stumps.
A small but heavy duty brush hog on a BX will cut anything that a bigger one would. I run a 40" HD Gearmore on my BX2200 and it cuts 14' high weeds and clusters of 2" thick sapplings.
/ BX2350: How Much Work Capacity? #9
I have the B7510 that is only one step up in size from the BX. If your primary use for the FEL is to clean stalls and move feed you will be very happy with it, but for snow removal, it would depend on the length of the area you want to clear. Other then that it will make all the chores you mentioned a breeze that you use to have to do with a shovel and wheelbarrow and got tired doing. Like most of us I think even you would be surprised how much that little thing can handle. If you get it I'm sure you will be able to use it for some of the very small tasks that you do with the bigger machines. I guess it would be like putting a Leatherman tool/knife on your belt next to a machete.
/ BX2350: How Much Work Capacity? #10
I guess it would be like putting a Leatherman tool/knife on your belt next to a machete.[/QUOTE]
That's a perfect description. Both will do the job but each one is so much better for certain jobs. I love that description!!!
/ BX2350: How Much Work Capacity? #12
gunpaq said:
~~~~~~~~~~~~Will the BX2350 actually perform or is it a glorified garden tractor?**************
I have a top of the line Cub Cadet Garden tractor and a Kubota BX 23 Sub Compact.
The CC is a great machine but believe me there is no comparison between it and the BX23.
The difference is so great between a garden tractor and a BX that I just recently bought a BX1500 to replace the Cub Cadet and a second BX1500 to mow around the house with.
Just like I underestimated the BX23 when it bought so did I with the BX 1500s as they also never cease to amaze me to.
/ BX2350: How Much Work Capacity? #13
If you cruise up to a stump and expect to pop it out like you would with a 60,000# CAT Excavator, you'll be pretty disappointed.
If your only frame of reference is the biggest Crapsman made, you will be VERY pleased with the amount of work this series of machine is capable of...considering it could DEAD LIFT and carry the biggest Crapsman made...
I have put a measured 640# (of softener salt) in my FEL and carried it around the yard without any problem. Note that the loader is 'officially' rated to just over 500#.
/ BX2350: How Much Work Capacity? #14
The BX is perfect for your apps. Especially considering that you have other larger machines. The biggest advantage of the BX in comparison to the L, M and even the B-series machines is it's manuverability. For that reason I wouldn't recommend the B unless you didn't already have the other larger machines. It's capabilities are the same, just scaled proportionately. I use a BX1500 for several of the same or similar tasks you mentioned.
/ BX2350: How Much Work Capacity? #15
What shocked me was to realize within a week of getting my 2 BX1500 tractors that I could have done everything with a BX 1500 I'd done with the BX23 except the Back hoe jobs.
Would you trade your BX1500 for a JD x729,x749 or other JDx700 series?
/ BX2350: How Much Work Capacity? #16
Reading the OP again, I am absolutely in agreement that the BX would be the way to go. It will be much more capable than you imagine. It is VERY maneuverable and you won't run out of finding things to do with it anytime soon.
/ BX2350: How Much Work Capacity? #17
Thank you.
Hi I bought my BX24 in november-07, till today Ive done 100hours, mostly construction works for clients. I bought (in US) the bx not have seen in real life because I live on the other side of the globe....First when I saw it I got scared...Man that was a very small tractor:eek: BUT now after 100hours of hard work Im impressed...REALLY impressed, as many guys say and I agree, it wont lift to heavy loads on the FEL, but it lifts alot compared to its size. Sometimes you forget that u are using a small tractor so u go wild and try to lift stuff it aint made for...;)
I would recomend the BX for U
/Sam
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2018 Volkswagen Tiguan SUV (A64557)
2018 Volkswagen...
2024 HITACHI ZW95-6C WHEEL LOADER (A65053)
2024 HITACHI...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
