BX23
cag
Platinum Member
Ottawa. Ontario, Canada
Grizzly 660 Kioti DK45SE Cab
First time on this site.Looking to purchase small compact tractor for light work on our property.I understand that the BX23 is good value for the money, would there be other machinery on the marker similar to Kubota BX23? I'm shopping around. Thanks, Charlie from Canada.
The Massey-Ferguson GC2310 is very similar to the BX23, in fact some of the specs may be slightly better, or so I've heard. I've never seen one myself, but I've seen posts here on TBN by some very satisfied '2310 owners. I think someone mentioned a similar New Holland outfit that either is available or coming soon -- I'm sure others will fill in the details on this.
Massey GC2310 is the only comparable tractor in the class of the BX23. It is very similar in size. You leave the 3 point hitch in place when the backhoe is on and the Massey engine is rated at a lower RPM 2600 compared the Kubota (about 3200 RPM). Both are excellent machines. I feel the Kubota fit and finish are more refined although you have to remove its 3 point hitch to attach the backhoe. I think Iseki makes the tractor for Massey and their engines and tractors run very smooth. I would compare both to see which appears better to your likes and comfort. Again both are very good machines.
/ BX23
Thanks for the input Rimmer, greatly appreciated. I looked in to the GC2310 TLB and I have to agree both machines are quite compatable.
Could be wrong. But doesn't Kioti offer the CK 20 ,which is roughly in the same spec range ??
/ BX23
Thanks Nik for the input, I like the idea that the GC2310, 3 point hitch stays in place. I have seen the BX23 but the Massey Furgerson dealer did not have GC2310 in stock. I have to admit the BX23 is impressing.
CAG,
The BX or similar sized tractors may be perfect or less than you need, it depends on what you actually want to do.
If you give a little more info about your needs, members here may be able to give you additional advice.
They will probably say buy bigger! /forums/images/graemlins/grin.gif
I know you said light work, but once you have your tractor you will be surprised how much work you can dream up. Things you would never have attempted before, will happen almost in a blink of the eyes...
Enjoy the selection process... /forums/images/graemlins/smile.gif
/ BX23
The BX 23, so far, seems like the right size for travelling on a barge as we own property on an island. The tractor would be used for filling holes, cutting grass, and the hoe would be of great use for removing old stumps.
</font><font color="blue" class="small">( The BX 23, so far, seems like the right size for travelling on a barge as we own property on an island. The tractor would be used for filling holes, cutting grass, and the hoe would be of great use for removing old stumps. )</font>
They have cars now that can swim, why not just put a prop on your PTO? I recomend the 4 bladed one!! Then you can get any size tractor and have the tractor pull the barge!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
OK all kiddin behind. For what you need the sub-compact will do just great for you.
murph
/ BX23
/forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif I agree with the 4 prop and while at it, might as well install the optional helicopter prop /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
CAG
I have no idea as to what any of them weigh /forums/images/graemlins/smile.gif
But, as you were looking for tractors in that size range ,and the CK hadn't been mentioned , I just added it to your list of possible machines . Heck there's probably more to boot !
Just study each machine ,and your needs . Then buy the one you're most comfortable with . All the best , John
BTW welcome to TBN !!!
I maybe mistaken but I believe the wheel base is shorter on the Bx as well as it is lighter. I think that the hoe on the BX might be closer to the back of the tractor to make climbing steep inclines easier with out digging in. Most times it only takes 5 minutes to remove or the reattach the hoe in between using the three point hitch.
/ BX23
I'll be looking into it, all I have to do is find a Canadian dealer.
Thanks Don
/ BX23
So far I received Quotes For BX 23 And GC2310TLB Both dealers were great. GC2310 TLB is about 2000 cheaper but dealer did not have tractor in stock. I'm still trying to find a Canadian Kioti dealer, does anybody know where I can find one?
On the Kioti "dealer search" page it asks you to contact Kioti via email for a list of Canadian dealers.
Don
/ BX23
Thanks for the info Don, I did just that and now I wait. /forums/images/graemlins/smirk.gif
Canada? Island? Isn't the lake frozen over right now. Drive it over and leave it.
/ BX23
I guess i could do that but rather keep the tractor on mainland /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
C&S FARMS AUCTION - IN LOVING MEMORY OF JACKSON STRICKLAND. (A64277)
C&S FARMS AUCTION...
(12) 4.5"x9' Steel Posts (A66408)
(12) 4.5"x9' Steel...
1999 Volvo Day Cab Truck, VIN # 4VA7BBRF8XN767346 (A65563)
1999 Volvo Day Cab...
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
