BX23 vs BX22 What is the Difference?
   / BX23 vs BX22 What is the Difference? #1
pncmathias
Lower Bucks, PA
Kubota BX23 TLB
Hi,
I am going to look at a BX22 which has 50 hrs and is said to be in "as new" condition. How much do the loader controls and ease of removal differ? What else is there? Does it still have cruise control? What is something like this worth? I have found used BX23's with 200+/- hrs for $13k asking. Thanks!
Paul
   / BX23 vs BX22 What is the Difference? #2
The loader valve is better on the BX23 and if there is a choice, I would go with the newer machine vs. the older one, even if the hours of service are more. The machines are guaranteed by number of months of service, not number of hours, so even though the newer machine has more hours, it also has a longer warranty. Neither the BX22 or the BX23 have cruise control available for them. With very few exceptions, they are both identical machines outside of the loader issue.
   / BX23 vs BX22 What is the Difference? #3
Mr. Junk:
You and I have the 22. When I purchased my machine, I got the upgraded valve (four-way vs. three way?) for the FEL. My valve stays on the tractor when the FEL is removed. If pncmathias is looking at a 22 with the upgraded valve, I think that the only difference would be some extra safeties on the seat of the BX-23. I THINK!
   / BX23 vs BX22 What is the Difference? #4
You have to have one of the very last BX22's to be made then. Mine was delivered in October and it has the old style of valve. The older BX23's have the BX22 engine, but I believe that the newer BX23's have the later engine that doesn't accommodate the engine block heater. You are correct on the seat switch. Junk....
   / BX23 vs BX22 What is the Difference? #5
Junk:
I should have been clearer. The valve that I have was an upgrade to the tractor. It was swaped-out by the dealer for a cost of about $70.00. My salesman said the four-way valve, if bought seperetly would be about $450.00.
   / BX23 vs BX22 What is the Difference? #6
Do you have the new design valve that comes with the BX23 or is it still the type that came with the BX22? I know that the 3 way vs. 4 way valve is about a $75 difference. I believe that the 3 way is no longer available with the BX23 since they went to the new design. I don't know what they have done with the rest of the BX series tractors.
   / BX23 vs BX22 What is the Difference? #8
</font><font color="blue" class="small">( ........... My valve stays on the tractor when the FEL is removed. .............. )</font>
Only the BX23 has the valve that stays on the tractor when the FEL is removed. If you want the valve on the tractor when the FEL is removed, then you have to remove it from the FEL after the FEL is removed and reinstall it on the tractor. This is a royal pain to do. I intend to make modifications to my tractor to alleviate this nuisance of poor Kubota design.
Thanks for the input. I think I am going to go the route of a new BX23. The price difference is just not there. Thank You!
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
2705 (A51691)
2705 (A51691)
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
International Tractor w/Belly Mower (A50774)
International...
2014 DOONAN (CHAPARRAL) 502BBNHTTBZF 50FT CONESTOGA XP SPREAD AXLE FLATBED (A52141)
2014 DOONAN...
