Oil & Fuel bx23 fuel gauge
   / bx23 fuel gauge #1
opreeder
my bx 23 fuel guage doesnt work. I believe it is in the sending unit but i cannot locate it.
   / bx23 fuel gauge #2
It's on top of the tank above the left rear whee (opposite side of the fuel filler)l. Unfortunately you'll have to remove the ROPS, some assorted minor parts and the rear fender/floor pan to get to it. It's not major surgery but give yourself the good part of a full day to do it.
A search will turn up several threads of those that have done it.
Dave
   / bx23 fuel gauge #3
The BX2200 has a two stage sender. It may be the same with the BX23. If the replacement is done wrong the second stage won't send and the fuel level will read about 3/8th of a tank until it actually reaches 3/8th of a tank and then it will read correctly from there on down. Sometimes if a bump is hit really hard the second stage will engage and the fuel level will read correctly for a while.
The key seems to be to rotate the sending unit just right until the second stage engages - permanently rather than intermittently.
Getting to the sender is a pain. Good luck.
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
10' CONTAINER (A51248)
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
