Oil & Fuel bx23 fuel gauge
   / bx23 fuel gauge #1
opreeder
my bx 23 fuel guage doesnt work. I believe it is in the sending unit but i cannot locate it.
   / bx23 fuel gauge #2
It's on top of the tank above the left rear whee (opposite side of the fuel filler)l. Unfortunately you'll have to remove the ROPS, some assorted minor parts and the rear fender/floor pan to get to it. It's not major surgery but give yourself the good part of a full day to do it.
A search will turn up several threads of those that have done it.
Dave
   / bx23 fuel gauge #3
The BX2200 has a two stage sender. It may be the same with the BX23. If the replacement is done wrong the second stage won't send and the fuel level will read about 3/8th of a tank until it actually reaches 3/8th of a tank and then it will read correctly from there on down. Sometimes if a bump is hit really hard the second stage will engage and the fuel level will read correctly for a while.
The key seems to be to rotate the sending unit just right until the second stage engages - permanently rather than intermittently.
Getting to the sender is a pain. Good luck.
1997 John Deere 8100 MFWD Tractor (A53472)
1997 John Deere...
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
2001 Dodge Ram Wagon 3500 Passenger Van (A51692)
2001 Dodge Ram...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
