BX23 Floor Replacement
/ BX23 Floor Replacement #1
toadmiller
Kubota
Greetings I知 in a heck of a mess. I own a 2004 BX23 (serial 67062) that has a rotted-out floor. The part number is K2561-95510. I have placed orders with two suppliers only to receive a call back a day later indicating they don稚 have the floor in stock. I have also called four other dealers in the U.S each of whom showed the part on hand only to find out they don稚 actually have one. Worse, Kubota has apparently discontinued production on this part!
1. Does anyone have any sources they could point me to in an effort to locate a floor?
2. Does anyone know if Kubota has a cross-reference to a compatible floor (都tep kit? under another part number?
Thanks in advance for any help you might offer.
/ BX23 Floor Replacement #3
Any dealer can put the part number on a dealer stock locator and print the results showing dealers that could have the part in stock.
Any dealer can enter the part number in a Model Used On search and tell you if any other models use that part. That will aid you in searching salvage yards for a used part.
Edit:
Currently the locator shows two dealers with possible stock. One in Maine, the other in NY State.
Edit:
Yes, I tried that. I've called every dealer in the U.S, that shows one in stock, not a one has it on the shelf. Thanks for the suggestion though, I appreciate it. / Todd
Yes, thanks though. No luck there either. This is really a tough one.
/ BX23 Floor Replacement #6
I’d probably get it welded up, you could probably scratch build a floor to get by.
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
GREENHECK AIR DUCT FAN (A60432)
GREENHECK AIR DUCT...
CAT 930M (A58214)
CAT 930M (A58214)
