It only ended up only taking me 8 to 10 minutes to remove the curl cylinder and it was super easy. I think it was harder for me to install a FEL bucket pin.
Basically I took the cotter pins out, removed bottom bar pin first, then the two hoses, sealed then in a rubber glove to keep dirt out. The top bar pin was a little harder and I noticed the dealer only greased the bottom pin and the top was almost dry. This pissed me off as I just finished paying for a full servicing and this was supposed to be done. Now I wonder what else they took a short cut on. I drove the cylinder to a hydraulic repair shop figuring this is all they do and I have to start somewhere to find good people.
I want to pass on my
BX23 went in for servicing 4 weeks ago and I just got it back a couple days ago after being promised a quick turn around. I actually approached the dealer 8 weeks ago, but because his mechanic was going on vacation I had to wait 4 weeks, thus the reason for the quick turn around promise. I asked the dealer to go thru everything as I was taking the tractor two hours away to start working on land I own and I didn't want to run into trouble. Was told everything was done after a week but the bad news was the BX needed a fuel sending unit. Not hearing from these guys after another week, I went by the dealer a and was told the sending unit would be in the next day, but couldn't get to it. On week three I find out they still did not install the sending unit and when I inquired about the other work including new switches, I learned the work he said was done was not done. He promised me 100% it would be done the following Thursday and delivered. I get the call that Thursday they could not get the BH off and decided not to replace the sending unit. At this point I just wanted my machine out of there as I lost 2 months and now this happens. Get this - my machine is delivered minus the steering wheel cap.
My point in telling this story is I am grateful for the help on TBN, which helped me solve the issue quickly without the dealer run around. I do have another question. Before I put the large pins back in, should I clean out the area of old caked on dirt and grease the pins go in and if yes, what would you clean it with before coating with new grease? Would you use the same large pins or put new ones in as these have 450 hours on them. Thanks
Congratulations on jumping in and removing the cylinder. For the dirt and dried grease, I feel it is worthwhile to clean the area up as dirt and grease make an abrasive paste which is best not injected into the joint when re assembling. It is part of taking care and keeping your machine looking good.
As far as how to clean and what to use, you have a number of choices. First you need a solvent to dissolve the old grease and soften it. Everyone's first tendency is to use gasoline as people have it around for lawnmowers. I think that is a bad choice because of flammability. Varsol, which is used to clean paint brushes, will do the job and is cheap. Even diesel fuel is a solvent.
Next you should have some rubber, vinyl or similar gloves to protect your skin. These solvents will dissolve the oils in your skin leaving you dry and itchy. Further, through skin contact, the solvents are absorbed into the body.
The last items are a plastic putty knife available at paint stores, and a very stiff brush like the ones sold in grocery stores for scrubbing stuff. The plastic putty knife rather than a metal one because it will not scratch surfaces. The putty knife removes the large thick crud easily and quickly. Next you use the solvent for the final cleaning by painting it on and brushing it until the old grease is dissolved. Rags or paper towels finish up the cleaning.
If you were doing this type of cleaning often then a "parts washer," brush which has very stiff brisels will dissolve the grease quickly and will get into small places. These brushes are sold at auto parts places and Northern tool and similar. Not expensive!
Compare the two pins after you clean them and if they both look the same as far as wear and scratches, which is what I expect you will see, then reuse both.
450 hours may seem like a lot to you but reality is that these farm machines will run for 5 or 6,000 hours before needing serious engine work and then continue for another 4 or 5,000 hours before they reach the end of their lives with fenders falling off, electrical lights and switches broken etc, . All of this long life depends upon the use of the recommended lubricants following the warm up procedures in cold weather, use of quality filters and the use of the machine within its limits.
Once things are re-assembled, you can use the grease gun to lube the pins. Leaving this step until the cylinder is installed is just less messy for you as during the re attachment of the hoses you want to be keeping the ends of them and the cylinder ports free of any dirt and this is a lot easier to do with a second set of clean gloves.
Look forward to reading what the hydraulic shop found.
Dave
M7040
