BX2230 fuel problem
/ BX2230 fuel problem #1
dwn31
alcester, south dakota
37 farmall M. ford, kubota
my little Kubota is sputtering with no rhyme or reason. Coughs the same under load or just driving. Changed both fuel filters, air filter and oil filter. Still sputters. Tried seafoam and some other additive...no change. Usually only use it for mowing and light snow removal. Any thoughts would be appreciated
/ BX2230 fuel problem #3
....or possibly contaminated fuel (water maybe)...If you have not already done so, you may want to drain the tank and replace the fuel. Also it could be a vacuum lock...Have you tried loosening the fuel cap...there may be a screen on the fuel tank outlet that may be blocked....Either way it sounds like fuel delivery to me.
/ BX2230 fuel problem #4
I'll put my money on the kill switch. Just fixed mine with an identicle problem.Been intermitent
for a year..Usually when first starting out for the day. Pressure washed with seat up, and problem was
pretty well aggravated,ie. lean a little in the seat and engine shut down.
Fix is easy..... pick up a small tube of dielectric grease [auto parts store]
small fingernail sized dab in small mixing cup
equal amount of alcohol [rubbing alcohol will do]
mix vigorously.... [not all grease will mix in, but enough will]
With stir stick... apply liberally around switch button while activating
switch with finger, working the thinned grease down into the switch.
Now you should be able to bounce around to your hearts content without killing that
engine.
If this works for you..... please post back on this thread,as this seems to be
a very common problem, and your header will pull this up on a search of this thread.
Like I said, my money's on the switch for this problem. This switch is in the fuel delivery circuit as
it controls the engine stop solenoid.
Respectfully
Don
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
Covington TP-66 Planter (A64127)
Covington TP-66...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
