BX2200
/ BX2200 #1
Anonymous Poster
Epic Contributor
I HAVE A BX2200 THAT RAN GREAT UP TO HAVING 25 HOURS ON THE MACHINE. AROUND THIS TIME THE BX2200 WOULD LOSE POWER AFTER ABOUT 45 MINUTES TO 1 HOUR OF OPERATION. I TOOK THE BX BACK TO THE SHOP. THE DEALER HOOKED IT UP TO THE DYNO MACHINE, THEY COULD NOT FIND A PROBLEM. THE BX RUNS GREAT WHEN YOU FIRST START IT UP(COLD). IT SEEMS LIKE IT HAS ALL SORTS OF POWER, AS YOU MOW OR TILL WITH IT THE POWER GOES AWAY. A SMALL INCLINE GIVES ME PROBLEM ANYMORE.WHEN I LOSE POWER I WOULD HAVE TO SLOW DOWN OR COME TO A STOP AND ALLOW THE ENGINE TO COME BACK UP TO SPEED.THE FUEL FILTERS HAVE BEEN CHANGE THREE TIMES.I CAN TAKE A SHARP TURN WITH THE MMM ENGAGE AND THAT WILL PULL THE ENGINE SPEED DOWN.I CAN GO UP A SMALL INCLINE WITH THE MMM ENGAGE AND NOT ACTUALLY CUT GRASS AND THE ENGINE SPEED WILL COME ALMOST TO A STOP.IS THIS NORMAL FOR THIS BX2200 AND AM I EXPECTING TO MUCH OUT OF IT.TODAY THE FUEL TANK STARTED LEAKING . I HAVE 175 HOURS ON THE MACHINE AND I HAVE BEEN DISAPPOINTED IN THE MACHINE. I NEED HELP PLEASE.
ANY SUGGESTIONS.
/ BX2200 #2
Sounds like fuel probhlem or maybe something like a blown head gasket....although a head gasket problem should be noticeable right off.
There was a thread recently about the fuel solinoid valve on a couple of units shorting out. This solinoid is supposed to either allow the fuel to flow to the engine or not. Go no go. Maybe afer a while it is beginning to close....just a thought. Fuel pump problems could manifest themselves this way as well.
Is the temp gauge staying in your normal range? Is there enough coolant in the radiator?
The bx 2200, I have one, has one tough motor so it should not crap out after a while of use.
Hope your dealer can get it fixed!
/ BX2200
Being a diesel it pretty much has to be either starving for fuel or starving for air. More than likely it is starving for fuel. The fuel solenoid is a good place to start knowing its history of premature failure. I highly doubt it is a high cost problem, just a major aggravation.
Good Luck!
Clay
/ BX2200 #4
Another thought.....did the dealer or you replace both fuel filters? maybe one is plugged! just a thought
/ BX2200 #5
Fuel tank cover may not be venting properly and is creating a vacuum as it is sucking fuel from tank. Try running with cap a little loose and see if problem still occurs if it does not then problem solved.
/ BX2200 #6
Bolynn,
</font><font color="blue" class="small">( I CAN TAKE A SHARP TURN WITH THE MMM ENGAGE AND THAT WILL PULL THE ENGINE SPEED DOWN.I CAN GO UP A SMALL INCLINE WITH THE MMM ENGAGE AND NOT ACTUALLY CUT GRASS AND THE ENGINE SPEED WILL COME ALMOST TO A STOP.IS THIS NORMAL FOR THIS BX2200 AND AM I EXPECTING TO MUCH OUT OF IT.TODAY THE FUEL TANK STARTED LEAKING . I HAVE 175 HOURS ON THE MACHINE AND I HAVE BEEN DISAPPOINTED IN THE MACHINE. I NEED HELP PLEASE.
)</font>
---The way you say the engine acts definitely sounds like a fuel problem. Bummer on the tank - I'd heard that they had problems in the past with them but my dealer said they have since been fixed. What year is your machine? I just got my BX2200 and only have about 4 hours on it - mostly mowing - but mows fine. Sounds like your fuel is not free flowing. Maybe the tank has a crack in it causing a loss of suction?
Sorry I can't be of more help,
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2019 ASV RT-25...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
