BX2200 WHEELS WON'T SPIN
/ BX2200 WHEELS WON'T SPIN #1
JMP
IL
BX 2200
BX2200 WHEELS WON\'T SPIN
HAVE A BX2200 FEL,60MMM, WITH 70HRS. WHEN DOING LOADER WORK AT 3/4 THROTTLE THE TIRES DON'T SPIN WHEN PLOWING INTO A PILE OF DIRT( 2WD). THE TRACTOR GRUNTS LIKE IT IS UNDER POWERED. IS THIS RIGHT? SEEMS TO ME WHEN I FIRST GOT IT I COULD SPIN TIRES IN 4WD. PLEASE INFORM.
WOLFMAN.
/ BX2200 WHEELS WON'T SPIN #2
Re: BX2200 WHEELS WON\'T SPIN
When cutting into the pile I mistakenly try to floor the hydro pedal. I realize that I should let off and I'll get more power from the hydro. The only time I can spin the tires is when I am on very soft material. But I am using a B2710 and am in 4WD when I do loader work. I don't think you have a problem.
Turfman
/ BX2200 WHEELS WON'T SPIN #3
I have a 2910 and when that happens I am usually in the wrong gear, try putting tractor in lowest gear when doing grunt work.
/ BX2200 WHEELS WON'T SPIN #4
In high range, my BX won't spin in 2wd or 4wd. Low range, it spins plenty, especially if I am doing some quick work and don't add my counterweight.
THANKS TO ALL THAT RESPONED. I FOUND THAT I WAS IN HIGH GEAR. TRIED IT IN LOW, AND DURT WAS A FLYING.
THANKS AGAIN.
WOLFMAN.
2003 Freightiner FLD120 (A61306)
2003 Freightiner...
2011 Ram 1500 Pickup Truck (A59230)
2011 Ram 1500...
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
2012 International 4300 Reefer Truck (A61306)
2012 International...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
10' CONTAINER (A52706)
