BX2200 mower deck.
   / BX2200 mower deck. #1
davesl708
Elite Member
Shawnee, KS, USA
Kubota BX2200D,
Hi everyone.
I have a RCK60BX mower deck on my 03 BX2200.
My question to you folks is the clearance of the deck to the rear tires. After all these years I noticed the gap between the rear tires and the deck is different on the left vs right side. On the right the deck clears by 1/2", on the left the clearance is 2".
I don't see anything bent and have not hit anything hard.
If you have a BX2200 with 60" deck is this normal gap or do I have a bent deck mount?
Happy Father's Day to you Dads. Hope you are having an enjoyable day.
   / BX2200 mower deck. #2
Shud b able to adjust side to side to be equal, then front to back w front side slightly lower
Mower cuts fine and deck is level with the slight drop in the front. the measurements I stated are with the deck in the Top position.
Seems if I twisted it, it would cut different. Just wasn't sure if it was the normal shape of the deck or something twisted.
I will double check the adjustments.
   / BX2200 mower deck. #4
Oh, read that too fast. Wudnt worry about it too much, as long as measurements at cutting position are good
   / BX2200 mower deck. #6
Hi everyone.
The bx23 I have and the clearance is different on both sides also. I think the 22 and 23's are about the same. Maybe just different looking but the decks are the same and connect the same.
Thanks Kentuckyfarmer. I may be worried about nothing.
   / BX2200 mower deck. #8
I have a BX2200 & used it for 15 years now with the MMM, 60 inch. Just went out to look based on your question and I see little/no difference left and right. I did not measure but certainly not as much difference as 1/2" versus 2". There are several possibilities:
1) Your moonshine is more potent than you thought it was.
2) One of the rear spring loaded pins may not be seated in the hole (which does not necessarily show.) Rock it around, look closely, and make sure it is seated.
3) I have not intentionally tried it but I seem to recall that it is possible to have the deck on there with some of the linkage on the wrong side of the piece it matches up to (??) Maybe not.
4) As you said, maybe something is bent.
   / BX2200 mower deck. #9
My BX22 has about that much difference too.
   / BX2200 mower deck. #10
I need to adjust mine as well. Mine does not currently have enough room on the left side to be able to rotate the wheels so that I can slide the deck to the side when removing. Looks like a simple fix (simply loosen the 2 bolts on the rear of the deck and slide to the side slightly?). I have the same deck as you.
   / BX2200 mower deck. #11
Do you have the pdf doc for the deck? If not I can send it to you.
   / BX2200 mower deck. #12
   / BX2200 mower deck. #13
Check out the attached pic...look at number 240...View attachment 512923
Granted, I haven't looked closely at mine lately, but the lift pin holes are welded to the bar that goes across the deck (130). There is a spring there to let it rock a little bit (240), but it rocks on that center pivot (150) which doesn't have any adjustment that I can see from the pic.
I measured mine with the deck on the floor at 1 5/8" on the left, 3 3/8 on the right.
Thanks everyone.
I will pull the deck today and take a closer look.
   / BX2200 mower deck. #15
I think that whole 130 bar can move from side to side if you loosen the two bolts (part 240)...there is a spring on each bolt that holds tension on the bar...the bolt does now go through that bar...not sure though since I have never adjusted mine...lol
   / BX2200 mower deck. #16
Looking more...I guess the bolts do go through the bar...however, the shape of the mount points on the deck appear to allow movement when tension on the bolts is lessened. Keep us posted if you beat me to an adjustment...
   / BX2200 mower deck. #17
Ok...so looking again...I think you are correct...no side to side adjustment...I guess the springs are simply there to dampen up an down movements? Sorry I wasted your time...lol
   / BX2200 mower deck. #18
Not sure what all questions have been raised but I think the diagram confirms there is no adjustment for either right/left nor fore/aft motion of that deck. The spring-loaded adjustment is for rocking motion in the roll axis only.
I am still quite puzzled how there is so much variation among us in the tire-to-deck distance on the left and on the right. Part of the difference may be in how the measurement is taken. I suggest a somewhat standardized comparison measurement is the nearest distance from the edge of the deck to the tire while the deck is fully "Up."
   / BX2200 mower deck. #19
On my deck, the back left deck wheel cannot be rotated counterclockwise 90 degrees for easy deck removal out of the side. The deck wheel hits the back left tire, so I rotate 3 of the deck wheels and keep the back left deck wheel pointed forward when removing the deck. No big deal, but I would like to shift the deck to the left side about an inch or so to allow deck wheen rotation.
   / BX2200 mower deck. #20
I measured mine from the head of the scalp wheel pin to the nearest rubber on the tire. Due to the curve of the tire, this measurement will change depending on the height. I can only remove my left rear pin when the mower is down. If it is up, the tire blocks the pin from being removed even far enough to change the scalp wheel. And I didn't wanna start the engine just to make the measurement. :)
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
2403 (A60432)
2403 (A60432)
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2018 F550 Bucket Truck (A61306)
2018 F550 Bucket...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
