bx2200 mower deck - left blade not loose & not cutting
   / bx2200 mower deck - left blade not loose & not cutting #21
The cup and washers under the blade could have worn some from the spinning blade. They are probable the reason you have to torque it down so hard. I replaced the cups and washers on all spindles and didn’t have a problem again after that.
   / bx2200 mower deck - left blade not loose & not cutting #22
There is a very tight tolerance on the thickness of the stack. Blade slip under loads wears all components of the stack a little at a time. Not much wear is accommodated before the internal hex [anti spin] washer can bottom and prevent the re tightened bolt from exerting its full squeeze force on the blade. More slip develops, etc. You dont notice until well along. A thin shim washer against the blade would renew correct function. Or its new parts time.
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2019 Nissan Versa Sedan (A50324)
2019 Nissan Versa...
KUBOTA SVL-75 SKIDSTEER (A52472)
KUBOTA SVL-75...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
