bx2200 mower deck - left blade not loose & not cutting
   / bx2200 mower deck - left blade not loose & not cutting #21
The cup and washers under the blade could have worn some from the spinning blade. They are probable the reason you have to torque it down so hard. I replaced the cups and washers on all spindles and didn’t have a problem again after that.
   / bx2200 mower deck - left blade not loose & not cutting #22
There is a very tight tolerance on the thickness of the stack. Blade slip under loads wears all components of the stack a little at a time. Not much wear is accommodated before the internal hex [anti spin] washer can bottom and prevent the re tightened bolt from exerting its full squeeze force on the blade. More slip develops, etc. You dont notice until well along. A thin shim washer against the blade would renew correct function. Or its new parts time.
DEUTZ MARATHON...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
2007 Hyundai Santa Fe SUV (A55973)
2007 Hyundai Santa...
New/Unused CFG Industrial MX50R Mini Excavator (A57453)
New/Unused CFG...
SULLIVAN PATEK AIR COMPRESSOR (A58216)
SULLIVAN PATEK AIR...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
