bx2200 mower deck - left blade not loose & not cutting
   / bx2200 mower deck - left blade not loose & not cutting #21
The cup and washers under the blade could have worn some from the spinning blade. They are probable the reason you have to torque it down so hard. I replaced the cups and washers on all spindles and didn’t have a problem again after that.
   / bx2200 mower deck - left blade not loose & not cutting #22
There is a very tight tolerance on the thickness of the stack. Blade slip under loads wears all components of the stack a little at a time. Not much wear is accommodated before the internal hex [anti spin] washer can bottom and prevent the re tightened bolt from exerting its full squeeze force on the blade. More slip develops, etc. You dont notice until well along. A thin shim washer against the blade would renew correct function. Or its new parts time.
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
2018 International (A56858)
2018 International...
KBH 25T Tender (A56435)
KBH 25T Tender...
