BX2200 Loader Problem
/ BX2200 Loader Problem #1
jrlichina
Platinum Member
Mukwonago, WI
BX2200, '52 8N
Next to the spools on the valve body there is a plug which I removed to see if that was where the relief valve adjuster was located. It was not so I screwed it back in but now the loader doesn't work. Since this is an opencenter system any air introduced should bleed out by itself. Any ideas?
/ BX2200 Loader Problem #2
Not being a BX owner, and having only looked at one once, I'm not familiar with them. What diameter was the plug? How long was it? Was it flat on the back side, with nothing behind it?
Do both FEL circuits not work? i.e., it won't go up or down, nor will it roll back or dump? Does it make any noise? Does the three-point hitch still work?
It must have been a stubborn air pocket. I tried it again this morning and now it works. The plug is typically where the pressure relief adjustor is, if the valve has one. Sometimes they put a plug cover to protect the adjustor mechanism. Since this was just a plug with a machined nipple on the end that would indicate that the vale has a no adjustment and uses the tractor hydraulics relief.
Thanks for the reply!
/ BX2200 Loader Problem #4
When I added the rear hydraulic remotes on my JD790. none of the hydraulics worked when I finished, I knew I had air in the system, but all attempts to get it out until I upped the RPM to 2000, operated the 3 point, heard a loud pop, I assumed it was a relief valve, everything began to work. Try this and see if it helps you. I was told the problem was the air was being compressed by the hydraulic fluid but not to the point of tripping the relief valve.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2016 Ford F-150...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2007 Isuzu NPR-HD Crew Cab Knapheide Service Truck (A64556)
2007 Isuzu NPR-HD...
2022 EZ-GO ELITE...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
